12-12-2020, 04:14 PM
Fresh Water Tank Drain Valve
OK, I hope this is a simple question...
I have a 2019 Force HD 37TS. Where is the fresh water tank drain valve?
My wet bay has hot and cold water drain valves, but I am guessing this is only for water in the lines.
I have seen advice about opening these, and turning on the water pump, but I question whether this will really drain the tank. I’ve also seen advice about turning on the outside shower, and turning on the water pump, but have the same concern. Also, I am sure there is crud in the tank, and it’s probably better not to run that through the pump.
There must be a valve for a gravity drain of the tank somewhere, right?
Like I said, I hope it’s a simple question...
Thanks.
12-12-2020, 05:26 PM
Left side wall in wet bay.
Gary & Janet
18 Force HD 37TS
18 Buick Envision
12-12-2020, 05:27 PM
in our BH model, the fresh water tank drain is in the propane cabinet.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
12-12-2020, 05:29 PM
I'm not near our unit but I recall it being located in one of the drivers side compartments forward within the compartment. Ours is labeled.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
12-12-2020, 08:33 PM
Thanks, but not in the wet bay, and not in the propane bay.
The hunt continues!
Anybody have a 2019 HD 37TS? Would be nice to know where it is supposed to be.
12-13-2020, 11:33 AM
Brian- Can you please answer or forward to someone in the company that knows the answer? Thanks.
12-13-2020, 11:43 AM
Have you located your fresh water tank itself?
12-13-2020, 12:05 PM
I believe the fresh water tank is below the bed in the back of the unit. When I look under the camper, I see some tubes coming down from under that area. These may be vents, or a place where the tank would drain, but there are no valves there.
12-13-2020, 04:27 PM
Commercial Member
The fresh water tank is below the bed. Have you lifted up the bed and opened the panel below it? that should give you access to the tank and likely the valve.
12-13-2020, 04:35 PM
Thank you Brian. I will check there as soon as I can find some muscle to help me lift it. I’ll keep you posted.
12-13-2020, 07:10 PM
Fresh water drain
This is in the upper left hand corner of the Aquahot bay, DX3 TS
Brian
12-13-2020, 07:12 PM
Thanks much!
