Originally Posted by sasha143
Hi I am about to purchase a 2020 Isata 3 24FW still under warranty. My question is this. I noticed that the top of the slide was all the way in and flush with the body but the bottom of the slide was sticking out 3/8-1/2". The horizontal rubber gasket at bottom of the left/right vertical edge was barely touching the coach and not compressed at all. I am afraid this would cause leaks. Can this be adjusted at a local dealer under warranty?
I notice you live in Florida, so temperatures should work in your favour for this test.
Press the button to extend the slide outwards, and hold it for another 3-4 seconds when the travel stops. Check inside and outside to see if he slide appears to equally seal itself in position.
Then press the button to retract the slide inwards, and hold it for another 3-4 seconds when the travel stops. Check inside and outside again.
Ken and Terry
