Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 08-25-2019, 11:52 AM   #1
hitchn2go's Avatar
Fuse Mapping for DX3 Electrical Bay
Does anyone have the mapping of the DC fuses in the Electrical Bay for a 2019 DX3. I assume it may be the same as other models/years too. I looked in the manuals and do not see it identified anywhere.
2019 DX3 RB
hitchn2go is offline   Reply With Quote
Old 08-25-2019, 12:27 PM   #2
CSWVK's Avatar
this is for our 2018 DX3
Name:	DX3 & Force Electric Bay Fuse  Block Relays Bird and 40 amp Mini Breaker.jpg
Cindy & Walt
2018 DX3 36FK
2015 JKHR - toad
CSWVK is offline   Reply With Quote
Old 08-25-2019, 01:24 PM   #3
hitchn2go's Avatar
hummm....that does not look completely like what I have. I have the 12 fuses (upper left) and the BIRD peaking out from under the red power cables (center), but the relays seem to have been moved...
Name:	EL Bay - Copy2.jpg
2019 DX3 RB
Old 08-25-2019, 01:37 PM   #4
this is a picture of mine
Name:	elec comp fuses and relays.jpg
Joe
2017 Dynamax DX3 37BH
Toad: 2020 Ford F-150
joet19711 is offline   Reply With Quote
Old 08-25-2019, 01:49 PM   #5
hitchn2go's Avatar
Yep, just base on the fuse sizes (color) looks like something is different in the 2019 DX3RB.
2019 DX3 RB
Old 08-25-2019, 03:02 PM   #6
Easy way to find out, pull fuse one at a time and see what goes out...
Joe
Old 08-26-2019, 11:38 AM   #7
hitchn2go's Avatar
Yep, that is one way to do but, but using that method may result in me missing something.
Hopefully, the factory has a fuse mapping they can upload for us so that we have the most accurate data.
2019 DX3 RB
Old 09-09-2019, 02:36 PM   #8
Señor Miembro
Rancher Rob's Avatar
While were asking for info, I'd like the mapping for my 2019 XL BH too please.
Rancher Rob is offline   Reply With Quote
Old 09-10-2019, 07:20 AM   #9
I am with Rancher Bob on this one - Fuse/components mapping of the electrical bay would be extremely helpful. Perhaps a place on the Dynamax site with directories by model, year, and some basic schematics and diagrams for owners to reference - Plumbing (Fresh, Grey, Black), Entertainment, Electrical (HV), Electrical (LV). With today’s drafting CAD tools it should be relatively easy to extract the various layers from IFC drawings and publish them as PDF files.
DieselBurn is offline   Reply With Quote
Old 09-10-2019, 09:18 AM   #10
KRedburn's Avatar
Agreed! A mapping of the electrical bay should be standard info provided along with the mapping of the relays in the "wet bay"
I find it curious why there are a multitude of relays and the connections in the wet bay. Seems to me they should be in the shore connection bay or generator bay NOT where a water leak may happen. Just two cents worth thought.
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
KRedburn is offline   Reply With Quote
Old 09-10-2019, 09:23 AM   #11
Commercial Member
I think on the new stuff, we've moved most things out of the wet bay....not sure what else is in there unless its tank reading related.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 09-10-2019, 10:21 AM   #12
KRedburn's Avatar
I am glad to hear that. Here is a picture of my 2018 37TS wet bay with its myriad of relays.
Old 11-28-2021, 02:55 PM   #13
Davenport's Avatar
Attachment 214586
Attachment 214591
I have the same relays in the wet bay. Did you ever get a mapping of what each one was for?
Davenport is offline   Reply With Quote
Old 11-29-2021, 03:40 PM   #14
KRedburn's Avatar
Unhappy
nope
AND
I have been unable to find any markings for identification.
Old 11-29-2021, 04:05 PM   #15
Commercial Member
I missed this one earlier as I saw a map posted. Didn't catch the "wet bay" portion.
It was a universal harness, thus the relays.
Old 11-29-2021, 04:32 PM   #16
Davenport's Avatar
Thank you sir for the diagram. that's what I was looking for, but it didn't shed any light on my problem. I've traced it down to 1 12v wire is bleeding over to the bedroom/bathroom lights., without a wiring diagram of the wiring itself the only option I can see is to tear out walls.
Old 11-29-2021, 04:39 PM   #17
Commercial Member
We recently saw something like this and it was the actual light fixture itself that was bleeding over.
Old 11-29-2021, 06:22 PM   #18
KRedburn's Avatar
This issue can be caused by the light itself or by a corroaded ground. Check your grounding posts on the chassis. There are several.
Old 11-30-2021, 04:43 PM   #19
Davenport's Avatar
I found my problem and it was a ground issue, bad propane solenoid feeding dcv to the ground lug, and a 12 pin connector behind the propane tank that feeds all the rear lights. The connector was corroded inside and one pin was actually corroded into. All this was bleeding dc voltage to the bedroom & bathroom lights causing them to glow when switch was off.
Old 12-19-2021, 02:37 PM   #20
CyberShanks's Avatar
Any chance of getting a mapping for these too?
2021 XL 3400KD
Thanks,
Jim
ID:	266861   Click image for larger version
ID:	266862   Click image for larger version
2021 Dynamax Dynaquest XL 3400KD
2021 Aluma 8220H Tilt flatbed to carry:
2012 Jeep JKU Rubicon or 2001 Jeep TJ
CyberShanks is offline   Reply With Quote
electric, electrical, fuse
