Old 09-21-2022, 04:37 PM   #1
ablarson's Avatar
Generator keeps shutting off?
2022 DX3 37BD
Generator shuts off intermittently. Checked oil and itís within range.
Batteryís all show fine on firefly.
No codes on firefly.
There was a wire that was unplugged on the inverter. I plugged it back in. It was either the remote or batt temp plug. I donít remember as they are both side by side.
Any ideas?
ablarson is offline   Reply With Quote
Old 09-21-2022, 04:46 PM   #2
nvs4602's Avatar
What's your fuel level? They will not run if fuel tank is too low. 1/4 tank if I remember right.
nvs4602 is offline   Reply With Quote
Old 09-21-2022, 05:14 PM   #3
ablarson's Avatar
Itís at about 1/2.
Iíll try to pull over and fill up to see if that solves it. Thanks.
Old 09-22-2022, 11:43 AM   #4
Also, aren't dash gauges notoriously off, and sometimes by a wide margin?
2023 Dynamax Force 34KD
-Demco Air Force One
2005 Toyota Tacoma 4x2 Crew Cab
-Remco 2pc Drive Shaft w/Disconnect
-Blue-Ox Avail Tow Bar and Baseplate
NewToTheForce is offline   Reply With Quote
Old 09-22-2022, 11:55 AM   #5
Commercial Member
yes, but normally the opposite way. (shows low when it is not).
Possibly it is low enough that sloshing drops below the take up tube? (at least that is easy to test).
No faults or anything else?
If "Search this Forum" does not yield an answer, please post questions as a "New Thread" (instead of sending a private message) so that others can benefit from the answers. Use Private Messages for sensitive information only.
Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 09-23-2022, 11:44 PM   #6
ablarson's Avatar
Topped off the tanks and it hasnít shut off since. So, either the tube is mounted very high which would be weird I think or it was purely coincidental 🤷🏼*♂️
Old 09-28-2022, 02:12 PM   #7
ablarson's Avatar
Itís back to shutting down. I stopped and checked fault code and itís reading
Fault code 27
Any ideas?
Old 09-28-2022, 02:40 PM   #8
cmulvey's Avatar
This may or may not be much help but a quick search on your fault code provided the following;
"Code 27 is a voltage sense fault meaning that the controll is not reconizing AC voltage being produced. Could be caused by bad brushes, bad wire or connection, A! controll or even the rotor or stator."
Christian M
2021 Forest River Forester 3011DS
cmulvey is offline   Reply With Quote
Old 09-29-2022, 05:18 PM   #9
Commercial Member
Someone else had this code either on FB or this forum....I think they finally got it resolved, but I don't recall the outcome. I would search this forum for that fault code.
Old 10-01-2022, 10:32 AM   #10
This happened to mine as well. Same code. It was the bedroom firefly remote that was bad - at least thats what the dealer said. We removed that bedroom remote from the firefly system and haven't had the AC issue since. Waiting on a replacement remote now.
TridentDynamax is offline   Reply With Quote
generator
