Originally Posted by Delco Bobby
Try letting your engine run for a few minutes and then see if the generator will crank.
^^^^ This. Your house battery might not have a full charge. I'd keep the engine running while trying to crank the generator. The engine in the REV will charge the house battery (assuming that the fuse on the battery hasn't blown as it did in mine.)
Are you plugged into shore power? If you are, unplug from shore power and then push the button on your control panel to see how much battery power you have. When you're plugged in the battery will show all the indicator lights lit up, but it isn't testing the actual battery.
If the battery is fully charged, then you've got a different problem.
Disconnecting the house battery while in storage helps, but it doesn't guarantee that it will be charged when you go to use the rig. Batteries do lose charge when in storage.
