Old 01-31-2023, 10:33 AM   #1
Generator Oil Change - ISATA5
Noticed this issue on an older post re: Generator Oil Change - Europa.
Our access door used to open on our ISATA 5 28SS. But, sure enough there has been some shifting and not so much access anymore. I was more concerned with the root cause behind a shifting 420 lbs generator. IMHO, not much shoulder for the 4 bolts to clamp on to the frame. Found some bolts looser than 20 ft lbs of torque (Onan spec calls for 31 ft lbs of torque). So, I added 3/8' washers with a 1" external diameter as shown in third picture, plus some thread locker and torqued to spec.
Coaxing that generator into position was the hardest part. With only one bolt out at a time, I used my jeep's jack and a large plate under the generator's center of gravity (as shown in Onan's Install document). Still needed a large C-clamp and some wood blocks to move the generator into alignment.
Cheers,
SParkie
Problem (notice the bolt shoulder v frame slot = not so much)
Name:	Gen Shift.PNG
Solution (notice the C-clamp and wood blocks)
Result (aligned door and larger washers)
SParkie is offline   Reply With Quote
Old 01-31-2023, 12:21 PM   #2
Commercial Member
I'll note this to production/engineering.
If "Search this Forum" does not yield an answer, please post questions as a "New Thread" (instead of sending a private message) so that others can benefit from the answers. Use Private Messages for sensitive information only.
Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
bclemens is online now   Reply With Quote
Old 01-31-2023, 12:37 PM   #3
Thanks for the acknowledgement.
Our rig has 13K miles on it at the one year mark and I'm sure that had something to do with it ! Many more Nationl Parks on the to do list.
Cheers,
SParkie
Old 02-02-2023, 04:17 PM   #4
Norwood Auto Italia
Brian, just an FYI but I had the same gotcha on my 2021 28SS. Resolved by loosening the bolts and using a transmission jack to move the generator and open access to the change port. Helluva job!
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2021 Isata 5 28SS Explorer
vlamgat is offline   Reply With Quote
Old 02-02-2023, 07:28 PM   #5
I had the same issue with my 2021 28SS; unfortunately, the bolts on my unit were either over torqued, or crossed threaded, resulting in 2 shearing off and 1 with stripped threads when I tried to loosen them to reposition the generator - leaving one bolt... I was unable to get the sheared bolts out using an easy-out, leaving me with the only option to drill out the old bolts and use nuts and bolts to clamp the generator down to the frame. Definitely not a pleasant event.
Dan
dtyo is offline   Reply With Quote
Old 02-03-2023, 02:48 PM   #6
Bill Davis's Avatar
FYI. Assuming the front of the generator on the I 5 is as accessible as on the M2s, the easiest way to service these units is to remove the front panel. It’s a dozen or so screws and the panel pulls off. You can then service it without having to crawl under the coach. Very easy. I never mess with that door on the bottom.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
Bill Davis is offline   Reply With Quote
Old 02-03-2023, 03:50 PM   #7
Norwood Auto Italia
Not so much. Many of the screws are hidden or obscured by the frame making it a slow and tedious job to remove the front panel. And there are a lot of them.
Old 02-03-2023, 04:11 PM   #8
Bill Davis's Avatar
Too bad, they are all out in the open on the M2.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Old 02-03-2023, 06:15 PM   #9
TrailWayz's Avatar
I change my oil all the time pulling the front panel. It's easier and cleaner. All screws are easily accessible.
-Brian
2020 Isata 5 30FW 4x4
2019 Jeep Grand Cherokee Summit
TrailWayz is offline   Reply With Quote
Old 02-03-2023, 06:25 PM   #10
halla's Avatar
Agreed. It only take a few minutes to remove the cover screws, then you can reach everything from the front, lot less mess and crawling around under the generator.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
halla is offline   Reply With Quote
Old 02-04-2023, 09:59 AM   #11
Bill Davis's Avatar
That’s what I said.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Old 02-04-2023, 10:20 AM   #12
Serrated washers
Cheers,
SParkie
Brian and Sparkie,
Instead of flat washers, consider the use of serrated washers or even external-tooth star washers. These will bite into the small surface area of those rails and do more to prevent lateral movement.
When I worked in the bicycle shop in the late 1950s, serrated washers were used to keep the rear axle from slipping in the slotted frame as the axle position was shifted to achieve proper chain tension. They are still in use today.
Larry
Larry-NC is offline   Reply With Quote
Old 02-04-2023, 06:44 PM   #13
Careful doing this. With mine the front panel and the top panel holes do not line up well, at all. Also, two of the top screws were forced in at a steep angle, because of this, they were stripped out (I'll have to see about getting this fixed). I did have to pull the front cover for the first change because the filter was installed so tight and/or without oil around the gasket, I couldn't get it off. The panel had to come off and I had to tear into the filter pretty bad to get it off (a bit of a messy job).
2023 Dynamax Force 34KD
-Demco Air Force One
2005 Toyota Tacoma 4x2 Crew Cab
-Remco 2pc Drive Shaft w/Disconnect
-Blue-Ox Avail Tow Bar and Baseplate
NewToTheForce is offline   Reply With Quote
generator
