11-26-2022, 02:00 PM
Norwood Auto Italia
Generator still running? Shore power off?
Try a set one of these. I have and they work to let you know anywhere that the rig is without 110V except to the extent of the inverter.
Only question is - do we have a single power point that is not inverter powered?
https://gfinotify.com/
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2021 Isata 5 28SS Explorer
11-28-2022, 07:48 AM
Yes there are parts of the panel not inverter powered. If there isn't a free breaker then replace 1 with a double (2 slims in the housing of 1 standard) and add an outlet to feed the device.
-2017 Isata 5 35DB (bunkhouse)
#teambunkhouse
11-28-2022, 09:26 AM
Norwood Auto Italia
Possibly but I am not an electrician and I don't trust myself with anything Neutral. It's just a contradiction in terms. But I do suspect but have not tested the outlet in the center P/S storage area is not inverter powered.
11-28-2022, 03:36 PM
Your 28ss does - the stove outlet for the outdoor kitchen.
This looks like it need fixed WiFi to work.
2021 Isata 5 28ss 4x2 / 2020 JLU Rubicon
Prior: 2016 Lance 1995 / Ram 1500 Eco Diesel
2012 Lance 1575 / 2015 Jeep JKU Rubicon
11-28-2022, 04:12 PM
It does need WIFI and chances are if the power goes out, so does the WIFI and no notification.
Days Camped: '18=48 ☼ '19=58 ☼ '20=110 ☼ '21=116 ☼ '22=112 ☼ '23=32
11-28-2022, 04:24 PM
They address that - in that case you would get a loss of power alarm.
This is a guess - they are just pinging the smartplug on a regular basis. If it loses comms, whether for wifi loss or individual circuit going dead, you get an alarm. Guess is continued - this is why they send two plugs, if they lose both, then presume the loss of power.
11-28-2022, 04:43 PM
We've been using Marcell, with great success, for the last 2 years. As we have dogs in the RV we want to know if we lose power and AC cooling if we leave our dogs in the RV. It alerts us if the inside temp goes over the set temperature. Not to mention that we have the generator set to Auto-start when we lose power.
Last year during Snow-Armageddon in Austin Texas we lost power several times and Marcell alerted us that power was off. No Wifi required, just plugged into any outlet with power.
https://www.meetmarcell.com/
11-28-2022, 07:04 PM
Norwood Auto Italia
That's correct. Similarly when power is restored, the ping response results in a restoration message.
This is a cost effective alternative to Marcell and others that require a subscription to a sim card or e-sim that is a very low power transmitter. so if it cannot reach a tower upon power down, that's it, no message. Whereas gnotify is continuously pinging your receiver through your WiFi network and theoretically is more likely to give you a false alarm followed by a restoration message if it fails to reach the coach network. Much like a passive transponder on a car or train.
11-28-2022, 07:05 PM
Norwood Auto Italia
Yes indeed, what about the outlet in the center P/S storage compartment? I have never tested mine.
11-28-2022, 09:01 PM
If all they are doing is pinging the puck, how do they differentiate between loss of power and loss of WIFI/internet it is connected to?
Sent from my SM-G996U using Forest River Forums mobile app
11-28-2022, 09:17 PM
Norwood Auto Italia
They cannot distinguish between the 2 events. That's just one of the weaknesses of the Internet in concept and execution. 99.9% uptime is still 9 hours of down time every year and all the aggravation that goes with that. Then there are at least 2 links in this network each of which can have a 0.1% downtime and it shows why you cannot make life dependency a function of the Internet. However if the alternative is no chance of notice of power outage, this has much going for it.
After all most people only have one cell phone network because they trust that someone "can hear me now" - eventually.
12-09-2022, 01:08 PM
They come in a package of two. I have one in the house and one in the RV. On hot summer days I need to know immediately when there is a loss of power. This is mainly for the dog. My super C heats up pretty fast when the power goes out. We have a hotspot that stays in the RV but this will also work off campground WIFI. I believe that the unit is pinged every 6 minutes. You get a text and email during a no power situation and the same notice when power is restored.
DYNAMAX 2016 FORCE HD
12-12-2022, 08:30 PM
Not intending to hijack, but I am curious about auto-generator start. I don’t think my 2005GTS has such a feature.
When I bought it It was hooked up to shore power…. Cool, everything works…. Then I asked to see it all work on generator…. My presumption (and even asking) was there was an automatic transfer switch if the generator was started while still plugged into shore power..
So far so good (I thought)
On the way home we decided to avail ourselves of a Walmart parking lot for the night. So, to be able to have a comfortable Florida night, I decided to start the generator to be able to have a/c ��.
Nope, didn’t happen…. Apparently there is not a transfer switch; when the 2 are connected…. There is a SECRET, to me, breaker in the generator compartment that has to be accessed in order to run the generator…. (Uncomfortable night spent)
Looping back to the original quote, is it possible to have an automatic start in a 2005GTS?
My WatchDog should notify me if I lose shore power, I think
Bill
12-13-2022, 12:42 AM
Watchdog will only tell you power is out, if you open the app and look. It does not send notifications.
12-13-2022, 08:31 AM
Bill
Highly unlikely there is no transfer switch. A generator usually has a breaker on it's output to protect it from overload. If that breaker is off then it won't feed any power to the transfer switch. Rigs that are built without a transfer switch are set up so that you plug the shore cord into the generator output so basically you the operator are the transfer switch.
#teambunkhouse
12-13-2022, 10:06 AM
Having slept on what I wrote….
Yes, WatchDog is a blue tooth monitoring device and not self powered so it has no way of notification
As to transferring, It seems to me that the generator was probably tripping the breaker to protect against backfeed to shore power
Bill
12-14-2022, 08:27 AM
Bill
Unlikely on that being the reason the breaker tripped. If the RV was wired that way then when not on shore power your male shore power cord end would be energized with the generator running. And starting the generator while plugged in to shore power would let magic smoke out of somehting when the 2 sources weren't in sync.
#teambunkhouse
12-14-2022, 01:19 PM
Ok, guess it will remain unsolved as I have never tried that combination again nor wish to experience magic smoke.
So it may have been coincidence or some other magic as I realize something must prevent backfeeding the shore power when the generator is running or viceversa.
And I understand the manual transfer method, I had access to a Rialto once upon a time
Thank y’all for your thoughts
Bill
12-14-2022, 02:52 PM
Bill
That something would be a transfer switch.
#teambunkhouse
12-14-2022, 06:17 PM
What do you reckon this looks like and where does it reside?
