Just put in a Glendinning Hosemaster on our 2020 Force 37TSHD, and need to connect it up to 12v. Thought I could tap into the macerator wires but they are only hot when macerator is on so that is not an option. Does anyone know of a hot 12v source close to the water/sewer compartment. Thanks.
I have a couple 12v wires that were not connected to anything inside my water bay. I would imagine that if you look you will find some there.
Dennis & Zoleta
Retired US Army
2010 Grand Sport GT
In our 2018 Force HD, I had a blue wire with a yellow stripe in the wet bay that I used for the water reel. It was tied up to the loom on the back wall behind the macerator.
I wont be around the RV until this weekend, but I am happy to get some pictures of the wires and where they are located. Shoot me a PM and I can email you whatever you need. I can probably get out there Friday.
Problem solved. While I found no hot wires in.the wet bay I did find a loom with a yellow and white wires zip tied outside the wet bay under the coach. They were even labeled "hose reel" so I fed them into the wet bay close to the reel. Works great. Thanks for all the help
