In my Isata 5, It appears that the drain pipe from my gray tank to the tee fitting where the bath sink join was not glued properly, if at all. The fitting is too tight to pull apart to get glue around the fittings to seal them properly. My question is..What is the best way to get the fitting apart?
My thoughts are to drop the gray tank, is this an easy job? Is this something a Mobile service person can take care of easily?
The pictures show where the drain is located. I removed a panel beside the bed to locate the leak.
