Originally Posted by MovnOn
Anyone come up with a way to reroute the washer (maybe a switch?) so that when you do have full hook ups you can switch it to a third outlet which can be opened to go into dump? Hope this makes sense.....
I did it my toy hauler. First, we like to keep our drain open for the washer/dryer so that we can run multiple loads of laundry a day without emptying it every 3rd load (family of 4 and we don't re-wear clothes). As well, I wanted to be able to dump the washer/dryer water on the ground in the right situation (private land where the land owner didn't want it in their septic tank).
Here's what I started with:
So, here's what I did...
First things first, my Splendide XC2100 combo washer/dryer called for 1 1/2" pipes. I tried doing this initially with 1" pipes and PVC ball valves and ended up with super messy geysers.
I bought a 3-way 1 1/2" pool diverter valve (
link).
I cut my drain pipe shorter so that I could install the diverter valve above it.
Note, while doing all of this, I had to cut out the RV box for holding these hookups and that meant cutting off the ends of the water hookups. Shark-bite fittings to the rescue here.
On the right-side, I have an inlet from the washer/dryer. Note the height requirements in your owner's manual. They were very specific about how high this can be.
On the left-side, I added a new outlet. I cut through the floor (with much measuring and a little bit of wishing that I didn't hit anything). This 1 1/2" outlet drops down to below my under belly. Down there, I installed a P-Trap (from Home Depot or Lowes). I picked one with a cap on the bottom thinking that if I ever needed to clean it out or empty it, I'd have a way.
In my case, this sticks below the under belly.
I then ran a PVC line to my camper's sewer outlet. It should have been ABS for weight but I couldn't easily find ABS.
I cut off the sewer outlet which was just a single straight shot. (Which yes, did include me getting one heck of a warm gray water bath because my idiot self told my daughter to grab a shower while I ran to the hardware store and then promptly forgot!)
I replaced it with one that had a 1 1/2" inlet off to the side (
link). I also added a T with a ball-valve so that I could dump this washer/dryer water straight to the ground without having to open my sewer cap. Note, I had to make sure I had specific glue for gluing PVC to ABS.
I did eventually close the area up with the same panel that was originally there with the corner trim and all. It's not the prettiest solution but for me, functionality was more important than pretty.
And, I'm pretty incompetent when it comes to doing things with my hands. Shark-bite fittings, PVC glue, and a whole lot of redo + trips to the hardware store .. I got it done. Anyone else likely would have done a nicer job than me.
Now, since this new washer/dryer hookup goes straight to the sewer outlet,
you will have a geyser if you ever forget to open it.
Now I have my choice, I can let this washer/dryer water go to the black tank or straight to the sewer or straight to the ground.
Obviously, you'll need to tweak this for your Dynamax. But longest story shortest, it's possible.
