Heat pump flickering/rattling sound
Hello everyone, I'm plugged in to shore power at home to 50 amp with a 30 amp dog bone to a 2021 Isata 3. Heat pump ON set at 70 degrees with the outside temperature 41 degrees. Everything seems to be working fine, and maintaining a constant 69-71 degrees inside. Except when it is running, it makes an obvious flickering sound outside on the roof. You can't hear it inside. Is that normal? Does it have anything to do with what I've read about heat pumps not being the most efficient around 40 degrees or below? I did run it a couple of days ago but did not hear the sound. Although, I can't remember what the temperature was then. Thanks again
