Old 03-21-2021, 11:29 AM   #1
Heat pump fuse
Hello there, as a newbie I'm trying to find the fuse location on a 2021 Isata 3. I seem to find everything else except for that, lol.
thanks
pelikan61 is offline   Reply With Quote
Old 03-21-2021, 11:42 AM   #2
The heat pump is your roof top Air Conditioner which is 120 volts AC. It will be on a breaker. The wall mounted thermostat is 12 volts I believe. What is not working?
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 03-21-2021, 12:49 PM   #3
You are absolutely correct, after you mentioned it was 120 volts AC it all made sense. I got it working. Thank you
fuse, pump
