Heat strips I5 30fw
I know that the two thermostats control front and rear AC’s respectively and only the front thermostat controls the propane furnace, my question is, is there only one AC unit that has heat strips?
I ask because we are here in Lubbock Tx headed home and it’s 32f, and I set both AC’s to elec heat and both blow air but only the front blows heat. Before I seek out service I thought I should ask here if anyone knows if that is actually as designed or if not is there anything I can check easily for possible simple fix.
This coach uses the airxcel thermostats.
Jeff
