11-04-2019, 06:13 PM
Help locating the other end of these wires
In this picture you can see two ( a red and a yellow each with a wire but on them ) wires that at one time prior to my ownership appear to have been connected to a inverter that was replaced with xantrex - I am upgrading to a magnum unit and we curious if anyone knew where these wires are “ at the other end “ my assumption is either in the area where the xantrex control head is by the thermostat or in the back by the intellipower unit is - any help is appreciated ?
Joe Pheifer
DX3
11-04-2019, 06:15 PM
No picture!!
Bob & Amely
2022 Dynamax DX3 BD.
(Previously 2018 Dynamax DX3 BH, with a years break between)
11-04-2019, 07:06 PM
Originally Posted by Motorhome1
No picture!!
Joe Pheifer
DX3
11-04-2019, 08:15 PM
The xantex shown in the picture is an 1800 watt inverter. It is what Dynamax installed that year I believe. It's what I have installed in my 2015. Not sure about the wires there.. The gray goes to the remote panel inside.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
11-04-2019, 08:18 PM
I would look around the battery(ies) for the other end of those wires.
11-04-2019, 08:29 PM
They look more 110 than 12v to me
Joe Pheifer
DX3
11-04-2019, 09:03 PM
I agree with MR DAN those are 12v wires much like the ones on the circuit breakers. A schematic from Forrest River for this area would be ideal. And again, the Xantrex you have is the one installed by Dynamax.
11-05-2019, 07:20 AM
Dynamax Service Rep
The wires in question are a harness pre-wire for powered macerator toilets. assuming you don't have power toilets in your unit is why your wires are not installed and capped and taped.
11-05-2019, 07:32 AM
Thank you for the information - do you know where these wires lead to at the other end?
Joe Pheifer
DX3
11-05-2019, 07:44 AM
The wires shown in the pic are 12 volts. 120 volts would have a white neutral and a ground wire and would be ROMEX. Not covered by split tube plastic.
You can get a wiring diagram from Dyamax possible on line.
11-05-2019, 02:38 PM
jkoenig24
My 2015 DX3-37RB has TWO "powered" toilets" but, I do NOT remember seeing those extra two wires. I'm currently in Elkhart and, said Xantrex 1800W Modified Sine Wave Inverted has been removed. I'm having solar panels and Lithium batteries installed (as well as other work). My "powered toilets" both work (although the red light REGULARLY comes on; even AFTER I've emptied my black & gray tanks). Gotta love the "quality components" Dynamax chose to install on an expensive coach (YES, I AM being sarcastic).
11-05-2019, 04:04 PM
Commercial Member
1. if you have two powered toilets you would not see those wires as those wires would be actually hooked up. There would only be two extra wires if your coach got a gravity type toilet. (as that is a common...IE standardized wiring harness)
2. The red light on the toilet coming on typically has nothing to do the with quality of the components. They have to do with either A: the location of the sensor...maybe it is set too low. OR, maybe there is sludge or toilet paper built up on the sidewall of that tank is is giving a false "full" reading.
In either event...the sensor that handles that red light comes WITH the toilet and the Tecma Silence is one of the best, most expensive toilets you can buy. So you are welcome for the quality components we chose to install. and I am not being sarcastic, its a pretty nice toilet, as far as you can call a toilet nice.
The sensors that WE choose and install on the black and gray tanks for "level" have nothing to do with the Tecma sensors...and you are welcome to sarcastically bash those because I have tried every single sensor known to man and they all have issues.
11-05-2019, 04:07 PM
Commercial Member
It's even Italian!!!
Tecma is an original Italian brand that provides well-designed and totally-reliable marine macerator toilets and bidets. Decades of experience and centuries of national traditions have lifted the brand to the top of its trade. Some design features are patented and Tecma products have won numerous international design awards.
11-06-2019, 01:16 PM
May be the lower end of solar prewire. The ones I have seen were 8 ga and came from somewhere in a cap on the roof
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
11-06-2019, 04:54 PM
Commercial Member
Thanks...this was actually answered in post #8.
11-06-2019, 06:16 PM
poor guy, he thought he had a couple of mystery wires and they end up being wired to the toilet.
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
11-06-2019, 06:55 PM
... although the member mentioning the “quality components” is not the OP. Let’s no get their wires crossed!
11-07-2019, 07:33 AM
So back to my original question - the location of the other end of these wires on the harness - from all the information that has been thrown around am I to understand the other end of these is in the bathroom somewhere near the toilet as they would have been used for a macerator toilet had my coach had one ?????
Joe Pheifer
DX3
11-07-2019, 07:56 AM
Dynamax Service Rep
Wires
That is correct,they would be behind a panel,or under the riser for the toilet.
11-07-2019, 09:29 AM
Thank you that’s what I wanted to know!
Have a great day and thank you to all for the valuable information
Joe Pheifer
DX3
