Old 06-15-2024, 06:35 AM   #1
Help! Slide won't work
Can't get dinette slide to come in. Switch won't engage. No fault code. Engine is running. Rear slide came in fine.
Survivor8199 is offline   Reply With Quote
Old 06-15-2024, 07:38 AM   #2
What year, make and model?
You can check the Slide Controller to make sure all of the connections are secure. I have seen people load or unload their storage compartments and knock a power wire off the Slide Controller.
Also check the Slide Motor Fuses.
Until you report back with more info, you can look at this video even though you don't have any fault codes.
Judge64 is online now   Reply With Quote
Old 06-15-2024, 01:50 PM   #3
What model and year?
I found when I had the same thing, I had to hold the button down for 4 seconds to get it to show a code. I then wrote this code down, did the emergency override and then had to reprogram the stops when I got home
I had exactly what you described absolutely nothing. No slide attempt to move, no fault code. Just looked like a dead panel.
2024 Europa 32KD
Europa32KD is offline   Reply With Quote
slide
