Originally Posted by Kenny kustom
I spoke to Hughes tech this evening...
While on the phone, we ran the generator and watched the Hughes.
It was cycling between pass through and boost, every few seconds.
He thought, maybe there was something that the generator was putting out, that the AF didn't like.
He mentioned he had not heard of this issue before.
I have two options..
1. Re wire the AF before the transfer switch.
2. Take the AF out of the loop, when not needed. ( I used the install kit)
This would take 30 seconds to perform.
I'm going with #2..
Well... I went with number one...
Re wired the af before the transfer switch. Running on generator, no boost and proper voltages.
Only other issue, is the ems doesn't like the Onan generator. It kicks out after a few minutes. So, either rewire
The ems before the transfer switch, or just run the ems in bypass when using/needing the generator.
