Old 10-15-2021, 11:40 AM   #1
How to fill FW tank in Isata 3
Today I want to Learn how to fill the water tank on my recently acquired 2017 Isata 3. We went camping, hooked up the water hose and used the water while we were on the site.
How do I fill the water tank for wilderness camping?
rchristian
rchristian is offline   Reply With Quote
Old 10-15-2021, 07:59 PM   #2
hhl
Anderson valve, switch to following.
PUMP setting, pumps water from storage tank RV.
CITTY setting, connected to faucet with hose at campground, Bypasses storage tank. Use pressure regulator.
TANK setting, to fill storage tank RV at home or campground.
Sanitize/Winterize setting is used to winterize RV.
ID:	264478Click image for larger version
Sent from my SM-G930T using Forest River Forums mobile app
hhl is offline   Reply With Quote
Old 10-15-2021, 08:07 PM   #3
Delco Bobby's Avatar
I am not sure about your model and don’t want to give you incorrect information but…
You may have something called an Anderson Valve. If so you will have multiple settings. One will be labeled city or public which sounds like where it is currently set.
You want to turn the valve to the fill tank position. After tank has water turn the valve to Normal.
Someone will correct me if you do not have ann Anderson Valve.
On my RV the valve is near the outside shower controls and water hose connection
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 10-16-2021, 08:42 AM   #4
Attachment 264478Attachment 264479
Thanks, this very helpful. I assume the water hose to fill the tank connects to the same fitting that is used to connect to city water.
Old 10-16-2021, 08:47 AM   #5
Bill Davis's Avatar
Correct.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
Bill Davis is offline   Reply With Quote
Old 10-16-2021, 09:05 AM   #6
Filling the Water Tank
Thanks again! We are seniors who are first time RVer's and I am so happy that I have joined the forum. I am not very "Hi-Tech" so do not fully understand the vocabulary of the younger folks when they explain.
On this forum I feel like I am in the right age group that will make life easier and more fun!
rchristian
Old 10-16-2021, 09:27 AM   #7
Another note, I don't have an Anderson valve but have read here and on other forums to be sure to relieve pressure on the system (turn off pump or city water and open faucet) BEFORE turning the lever on the valve. Seems many have broken theirs by not doing so.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 10-16-2021, 09:40 AM   #8
Bill Davis's Avatar
This is correct and good advise.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
