11-07-2022, 10:55 PM
How to replace porch light?
I ordered the replacement part from Dynamax but I’m told it doesn’t come with install instructions. Anyone know how it comes off and installs? I have a ‘19 RW but the porch light looks the same on most Dynamax RVs. It still works using the on/off switch at the entry steps but the area that I assume was the motion sensor is all rusted out.
11-09-2022, 01:20 PM
Commercial Member
I don't recall that we ever offered a porch light with a motion sensor. The porch lights are operated off of the on/off switch at the entry. To verify, I showed this photo to our lead service tech - Greg - and he, too, could not recall a time where we ran a porch light with a motion sensor.
So that leads to the question of what that rusting center circle could be. Maybe an aftermarket porch light or rather a screw that was added by a previous owner (Greg couldn't remember a time where we as the OEM ever has a center screw on those porch lights).
If the current light is working off the entry switch, then not sure I'd replace (since the replacement will have the same functionality).
If you decide to replace with the light you ordered, then you'll cut the seal around the current light (and likely remove that later-added center screw - if proven to be a screw upon further inspection). Then you'll pull out the black surround and find screws to fully dismount the light. Once you wire in the new replacement light you'll see that it screws into the wall behind the black surround and you'll pop on the faceplate and re-seal around it.
11-09-2022, 01:28 PM
Interesting, as I am the original owner and haven't touched the porch light. For now I just put electrical tape over the rusted hole as I suspected it could be the source of a small water intrusion. I will mull over how to proceed, I'm inclined to leave it as is for now given this additional info. I also question whether or not it is actually a screw in the middle, to me it looks more like the corroded element of a motion sensor.
And there is (or was) a model of that light with a motion sensor so I'm pretty sure that's what it is. See here: https://www.jupiterledlighting.com/led-porch-lights
11-09-2022, 01:43 PM
I wonder if the dealer replaced the porch light before you picked up the unit.
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
11-09-2022, 01:59 PM
That is very possible.
11-09-2022, 07:40 PM
Are you sure it isn't a screw access hole that you remove a screw to remove light sometimes it has a small plug that you remove then there is a screw in there to remove light from chassis.
11-09-2022, 08:49 PM
I can’t tell for sure, it’s very corroded.
11-09-2022, 08:58 PM
It might be a square head screw that is common on RV's. You can take a pick and clean out square and see if it is a screw. Looking at picture that what it looks like to me but I 'm not there to get a good look at it. It's not a true square but still looks like a screw. If you find out for sure let us know.
https://www.amazon.com/HORUSDY-4-Pie...s%2C133&sr=8-5
11-10-2022, 08:19 AM
I can see where it might be a sensor. Even looks like some of the plastic bubble around the edges.
Jim & Judy
2022 Istata3 FW "SweetBlue"
11-10-2022, 06:37 PM
Will the clear lens for lights pop off. I see two dark areas on the bottom of lens two bulbs in from each end that could be ears and it pop out from the top. Giving you access to bulbs and screws to remove light. You might check it out?
But I agree it does look like the Sensor you posted with the top cover missing. Those dark areas could be pry points also to remove lens.
11-11-2022, 12:00 PM
Commercial Member
That is 100% a robertson head screw.
Edit: 10%. Plus it looks like there might have been a plastic dome covering it at one time.
11-11-2022, 12:15 PM
Don't think I've ever seen a rectangular shaped robertson head screwdriver.
11-11-2022, 12:17 PM
Commercial Member
Looked more square to me...but then again.
11-11-2022, 12:44 PM
I agree with bubbles. rectangular not square
measured image proportions it is rectangular
11-11-2022, 01:29 PM
Robertson head screwdrivers do have rectangular heads. All squares are rectangles, but not all rectangles are squares
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
11-11-2022, 01:53 PM
^^x2. looks to me like a cap snapped in and the hazy ring around the O.D. is where the cap sat on the housing and a non stainless screw was used. My $.02
2016 Dynamax Force 35DS
2014 Chrysler T&C
On a Master Tow Dolly
11-11-2022, 03:14 PM
OK
Rectangle: a plane figure with four straight sides and four right angles, especially one with unequal adjacent sides, in contrast to a square.
Be sure and ask for a rectangle drive.
12-09-2022, 05:57 PM
Well, I took it to a local RV dealer and they confirmed the corroded object is a sensor and it is a 3 wire connection. They tried replacing it with the 2 wire light that I received from Dynamax, but it didn't work, so they put the original one back on. Oh well.
12-10-2022, 12:21 PM
Did the dealer verify the switch was sending 12v to the light?
i. e . I had an issue with the porch light and it was fixed by replacing the switch.
My light was dim and dealer thought it was the light. Wrong!
I found that the switch was not making good contact with the mechanism inside. Went to local hardware store and purchased same switch for a few bucks and haven't had any issues since.
Many dealer "repair" shops are parts replacers and do not investigate root cause of an issue. Then throw their arms up when the part replacement doesn't fix it.
You might try bypassing the sensor/measure the voltage to the light. The light should work. If not then I would investigate the switch.
12-10-2022, 06:32 PM
The switch and wiring work fine with the original light, which is back in place. The mystery at this point is how a 3 wire porch light with sensor was installed, although that is moot at this point; and how to replace it with the one I bought from Dynamax whenever I give that another try, most likely back where I bought it new 4 years ago at North Trail RV. I'm sure they can figure it out.
