Originally Posted by backdoctor
Hi. Will be picking up our 36ds in a month.
A couple of questions.
1) will the jacks lift the rear end off the ground in order to change the rear wheels?
2) is there a separate fuel tank for the generator?
I'll have lots more questions, but from lurking on this site I've learned lots already.
Agree with I5PhilGa,
Yes, you can use the jacks to lift the rig off the ground. Happens all the time even when leveling the rig at a campsite. I carry chunks on 2x8s with me to put under the tires because I don’t like having the tires off the ground for long periods of time (i.e. while camping).
The generator pulls from the main tank. The pick-up tube for the generator's fuel pump is supposedly set slightly elevated from the bottom of the tank so you cannot inadvertently run yourself out of diesel fuel while camping.
