Originally Posted by dannko
Could not do a picture from my phone so here is what mine looks like. Not sure how any gas venting is done, but there are no gas odors coming from the drain. Uh, this photo was shot horizontal, not sure what the heck this site does to photo's but others have said and had the same happen.
Whoa! That is different, isn’t it.
Total guess on this one, but I wonder if Dynamax did that when they fixed your vent stack for the black tank leak? Interesting to note that there is no hole in the wall where the original drain would have gone (like Casey’s and mine). The factory certainly would have had the resources to put new piece of wall board there though.
Again, total guess; there must be a trap or HEPvO below the shelf. There is a panel below that shelf that is hiding the ductwork for the bathroom heating register and for the wiring going to the bunkhouse TV. If you removed that panel, I bet you’d also see a trap of some sort and then a wall penetration where that pipe connects to the vent stack.
As for the picture, the site isn’t rotating the picture, it’s your phone. Your phone has software on it the correctly orients the picture for viewing based on how you took the picture in the first place. Remove the picture from the phone and orientation information is lost. Shouldn’t matter if it’s this site or if you removed the picture from your phone and emailed it to someone…..orientation information is lost. I use a picture editor to change and save the orientation when I take pictures with my phone.
