Old 09-28-2022, 01:02 PM   #1
Lvnthedream's Avatar
I5, 34DS Mattress Slide Issues
2021 I5, 34DS. For those that don't know, on a 34DS the bed stays flat it does not fold.
My bed slide is starting to make clicking noises and pops when opening and closing. I'm worried I'm about to have issues. I've re-adjusted the motors to be sure the wall is coming in straight and stopping in the correct locations.
I'm questioning the size (length) of the mattress (see photos). When the slide is in, it pushes hard against the dresser to the point of bunching up the end of the mattress (this is without sheets or a comforter on the bed). This just doesn't seem right to stress the motors that way. If I adjust the motors so it closes with the mattress just touching the dresser, there is a fairly large gap (3") outside where the weather seal does not come close to touching.
Last observation, the mattress is up against the headboard (not the wall). The mattress is thick enough it does not fit under the headboard. If the headboard was not there (mattress against wall) the mattress would not bunch up as much with the slide-in.
Other 34DS owners or Brian, any thoughts? See photos.
ID:	279808   Click image for larger version
ID:	279809   Click image for larger version
ID:	279810   Click image for larger version
2021 Isata 5, 34DS
Colorado
Lvnthedream is offline   Reply With Quote
Old 09-29-2022, 09:23 AM   #2
I'm no expert, but that appears to be the wrong size mattress... unless it's flattened out over time. If it were me, I'd probably either find a smaller mattress or have one made to fit that space. Slides repairs cost more than a new mattress.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 09-29-2022, 05:17 PM   #3
Commercial Member
That mattress is foam and fabric...compressing it 3" is not going to do anything to the slide motors. They are rated for far more weight.
If "Search this Forum" does not yield an answer, please post questions as a "New Thread" (instead of sending a private message) so that others can benefit from the answers. Use Private Messages for sensitive information only.
Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 10-04-2022, 09:15 AM   #4
OK, thanks Brian. I'm guessing with the clicking and noise the slide is making, I'm looking at a future slide problem/break. I can't find why it is doing this and the markings on the rail do not look good.
2021 Isata 5, 34DS
Colorado
Old 10-04-2022, 10:05 AM   #5
As I'm not a slide expert I would guess (SWAG) that the rack marks come from the slide motor gear moving your slide. I would check the slide alignment as it might be binding up towards the end.
msusslin is offline   Reply With Quote
Old 10-04-2022, 10:44 AM   #6
Yes, I've played with the alignment several times to be sure it is lining up however, thanks for the suggestion. None of the other rails are showing signs of wear like this one is.
2021 Isata 5, 34DS
Colorado
Old 10-04-2022, 10:53 AM   #7
Commercial Member
That very well could be, but the mattress shouldn't have anything to do with that. Something might have been misaligned at one time or is currently...so it is slipping. Could need a new motor and/or rack on that side.
slide
