Old 04-29-2017, 12:22 PM   #1
Ice Maker 2017 Isata 5
Other than the obvious lowering of the metal arm of the ice maker to make ice, is there something else to be done? My ice maker is not making ice. ANy help is appreciated. Thanks
Teich is offline   Reply With Quote
Old 04-29-2017, 12:32 PM   #2
Gumpster808's Avatar
May be a valve in the water line to the ice maker that is off since it was winterized...
Not sure where it is in your model but ours taps off under the fridge where the hot water heater bypass is located.
2014 3051S - First RV for us
Gumpster808 is offline   Reply With Quote
Old 04-29-2017, 05:07 PM   #3
Found it. The shut off valve is behind the wood grill under the fridge. Four screws to remove. Thanks
Old 05-01-2017, 05:18 PM   #4
Whalenss's Avatar
The shut off valve in mine is the cabinet under the bottom drawer next to the frig.
Pat
2017 Isata 5
Whalenss is offline   Reply With Quote
