Old 08-13-2023, 11:05 PM   #1
Installed KOOLRVs
I installed KOOLRVs in both ACs in my DynaQuest XL 3801TS.
The installations were pretty easy. Most of the time was spent using foil tape to make sure there were no air leaks.
They did provide a bit more air flow in various outlets, but I’ll wait to see if they actually help keep the coach cooler.
NOJO RV is offline   Reply With Quote
Old 08-13-2023, 11:38 PM   #2
The installations were pretty easy. Most of the time was spent using foul tape to make sure there were no air leaks.
I had looked at these and was curious how they performed. Thanks for the post!
2023 Dynamax Force 34KD
-Demco Air Force One
2005 Toyota Tacoma 4x2 Crew Cab
-Remco 2pc Drive Shaft w/Disconnect
-Blue-Ox Avail Tow Bar and Baseplate
NewToTheForce is offline   Reply With Quote
Old 08-14-2023, 06:22 AM   #3
Following
2022 Rockwood Signature 8324SB
2019 Ford F350 CCSB, 6.2L, 4.30’s
markcee is offline   Reply With Quote
Old 08-14-2023, 12:45 PM   #4
Man I wish I had known about this 2 years ago. I went with the RV Airflow inserts but for what they air, it was definitely pricy. But I will admit it did make a difference. The KOOL RV setup looks like it would have done just as well at a much more economical price.
2021 Wildwood FSX 190RT Toyhauler
2016 Chevrolet Silverado LT 1500 Crew Cab 5.3l 6L80 3.42 4x4
mikeyk101 is offline   Reply With Quote
Old 08-14-2023, 01:14 PM   #5
Norwood Auto Italia
Following
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2021 Isata 5 28SS Explorer
vlamgat is offline   Reply With Quote
Old 08-14-2023, 01:42 PM   #6
MSgt & MSgt, USAF Retired
clockcuff_66's Avatar
First I’ve heard of the Kool RVs. I’ve bought two sets of the others. I just hope it comes back from the factory with them still installed after they put a new roof on it. Let us know how they perform.
Chris and Joyce
2022 DX3 37RB 'Destiny'
2015 Rubicon
2020 Ultra CVO
Traded in 2020 ISATA 5 36DS
clockcuff_66 is offline   Reply With Quote
Old 08-17-2023, 09:17 AM   #7
asr524's Avatar
It would be interesting to know the cool down time with and without these.
2021 Wolfpack 315Pack12
2014 Ford F350 6.7L Diesel
2019 Indian Chieftain Dark Horse
asr524 is offline   Reply With Quote
Old 08-17-2023, 09:28 AM   #8
use some insulating material around it
may/might cut down on some of the noise
don't use spray foam ...
get some scraps of upholstery foam from a local upholsterer..
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 08-17-2023, 06:28 PM   #9
halla's Avatar
I have the RV Air Flow and I can say one side effect in our XL is a squeaking sounds from the styrofoam on the road. I have a Kool RV on order to see if that fixes the issue. We shall see.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
halla is offline   Reply With Quote
Old 08-17-2023, 07:16 PM   #10
If they are squeaking I’d think the a/c was loose. I haven’t noticed any abnormal squeaks in either rig we’ve installed them in. Can’t wait to see if it corrects it.
Chris and Joyce
2015 Rubicon
2020 Ultra CVO
Old 08-17-2023, 07:51 PM   #11
halla's Avatar
AC is torqued down properly. The styrofoam was a really tight fit, and it is that odd noise that foam makes, so we hit certain bumps, some that kind of twist the motorhome, that is when it squeaks. I know the squeak wasnt there before I installed it.
Old 08-17-2023, 09:17 PM   #12
MoJoe1003's Avatar
Strange, I installed the RV Airflow units in ours after we talked at the Rally and have no squeaks at all. Ours were an extremely tight fit, too. I did tape them up pretty good as well. The tape around the edges seemed to quiet them down even more.
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
MoJoe1003 is offline   Reply With Quote
Old 08-18-2023, 09:36 AM   #13
halla's Avatar
I was not pleased with the fit, it didnt go all the way up at the back side, so I am thinking it is rubbing on the metal plate.
Old 08-21-2023, 06:08 PM   #14
Mmgulfcoast's Avatar
Following
I have mine on pre order for September delivery. I made my own with styrofoam on my last MBS and it made a HUGE difference.
I’m hoping this new version will do the same on this MBS.
Will be interested to hear if you post an update…
Monica and Henry the cat in a mountain lions body
2019 Coachmen Leprechaun 319MB SOLD
2022 Thor Quantum Sprinter SOLD
2023 Thor Quantum 31LF TRADED!
2023 Forest River MBS 2400T
Mmgulfcoast is offline   Reply With Quote
Old 08-21-2023, 06:31 PM   #15
KOOLRVS
Just installed 3 weeks ago and happy with the results.
Pretty tough to tape around the duct connections so I cut small dowels to make a snug fit to hold fittings in place and used low expansion foam.
So far so good!
Buster Rockwood is offline   Reply With Quote
Old 08-21-2023, 07:18 PM   #16
Following
2017 MBS 2401W
BBogey is offline   Reply With Quote
Old 08-21-2023, 07:56 PM   #17
Following
2022 Rockwood 2442BS
2022 Ram 2500
She said I never apologize, I said "Sorry, but you're wrong"
Pharphr is offline   Reply With Quote
Old 08-21-2023, 11:12 PM   #18
Built my own at a fraction of the cost
I built my AC diverter box for our main AC in our 2015 Nitro XLR from green insulating board from Lowes. I followed directions from several YouTube videos. Total cost of board and aluminum tape was approximately $10.00. I also added a couple of small air dams, made from strips of scrap cardboard and covered with aluminum tape, to help divert some the increased airflow to the main cabin. The increased airflow was forcing the increased air volume to last vent in the garage. The mod increased the airflow tremendously and it decreased the cooling time by 60% by my calculations. It also decreased the noise in the main cabin by +80%. You can have a normal conversation now in the main cabin. I'm not sure why these new AC diverter mods are so expensive. I would think even a 3D printed unit would be cheaper. Since doing this mod, I haven't had to use the front bedroom AC much at all. Running it usually helps cool things down quicker and then we turn it off. All you need is the foam board, aluminum tape, tape measure, straight edge or square, and a jig saw. Took me about three to four hours to build.
JColeman is offline   Reply With Quote
Old 08-22-2023, 08:41 AM   #19
Will it cut down on the noise from the AC unit?
2005 Yukon XL 1500
2018 Prime Time Tracer 20RBS
corky310 is offline   Reply With Quote
Old 08-22-2023, 09:22 AM   #20
Smile
corky310, It reduced the noise tremendously!!! You can actually have a normal conversation without yelling and watch TV normally.
led
