You gents are not alone. We have a 2020 XL 37RB and had a severe water leak behind and underneath our shower enclosure. It turnout that the mixing valve was improperly installed, the shower drain was not sealed and the pipe from the shower drain to the grey tank had leaking fitting connections. Soaked the flooring above our rear most 2 compartments. The dealer, Van City RV, and Dynamax took care of us (thank you) but still these things should not have happened. It all has dried out but we now have loose tiles that still need to be addressed. Now a fitting is leaking under one of the bathroom sinks ....
2020 Dynaquest XL 37RB
