Old 05-23-2022, 03:13 PM   #1
jneum525's Avatar
Isata 3 - Anderson Valve - “City” Selection
On our recent trip, I connected the Motorhome to city water and turned the Anderson valve to the “City” (6 o’clock) selection, however I forgot to actually turn on the hose spigot. My pump switch was still in the on position.
Much to my surprise, water from the tank was still flowing from the faucet (when it was turned on) via the pump.
Is this normal?
Although I have never tried this before, I just assumed the Anderson valve needed to be in the “Normal” (12 o’clock) position in order to pump water from the MH tank using the water pump.
As soon as I opened the water spigot and turned the pump switch off, the city water flowed per usual.
Thanks!!!
jneum525 is offline   Reply With Quote
Old 05-23-2022, 03:53 PM   #2
I think it's normal. I vaguely remember making that mistake once. In fact, I didn't discover it until the middle of the night when I washed my hands and heard the pump turn on. Twasn't pleasant to go out in the middle of the night to turn on the spigot.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 05-23-2022, 11:32 PM   #3
jneum525's Avatar
Thanks …snowbird. I guess we both stumbled upon that. Just makes me wonder why the “normal” position even exists since the “City” selection appears to be a dual purpose selection.
Old 05-24-2022, 11:23 PM   #4
These are rvs. I gave up looking for logic in the way the components work long ago.
Old 05-25-2022, 10:16 AM   #5
Commercial Member
I also know....no matter how we design it, once it is out in the wild, someone will find a way to break it.
If "Search this Forum" does not yield an answer, please post questions as a "New Thread" (instead of sending a private message) so that others can benefit from the answers. Use Private Messages for sensitive information only.
Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 05-25-2022, 10:37 AM   #6
Very true.
I don't think it's the designers. They work with parts from other manufacturers and are dependent on information provided by the manufacturers. No matter how much quality testing you do, you can't test everything. Only 'real world' testing by owners reveal problems or gremlins.
Old 05-25-2022, 10:51 AM   #7
Commercial Member
Very true.
The biggest issue is really "weeding through the noise".
The loudest people are the ones where we are not building something the way that "they" use it. So we hear non-stop how it is an issue and its wrong. So we end up making a change....only to find out the majority of the people were perfectly happy using it the way that it was and now complain that they can't any more.
It's a never ending cycle.
select, valve
