11-17-2018, 12:27 PM
Isata 3 - Auto leveler service access
How do you service, check the fluid level, and add hydraulic fluid if needed for the auto leveler system in the Isata 3? Is it a "crawl under coach, reach up" kind of process or is there an easy to access secret compartment? I think I know the answer but just checking. Thanks!
SOLD: 2018 Dynamax Isata 3 24FW...delivered 12 Ap 18
11-17-2018, 07:42 PM
Here are a couple of Pics from the factory tour. It looks like it is almost impossible to access/service.
2019 ISATA 3 FW
LiFePO4 Upgrade
2013 Honda CRV Toad
11-17-2018, 11:44 PM
Yikes... Hoping for the secret compartment response but doubt that is the answer. Looks near impossible to access.
11-18-2018, 11:46 PM
Still looking for service/maintenance access information
11-19-2018, 09:56 PM
I will bump this back to the top. Seems like a very reasonable request to get an answer. Looks pretty tight to me.
2021 Isata 5 30FW
2022 Ford Ranger Tremor 4x4
(Previously owned a 2017 Isata 3 24FW)
11-20-2018, 11:14 AM
I have never had to check hydraulic fluids in tools or equipment. The fluid is not subject to high heat so it doesn't break down. The only problem I can see is air in the lines because of a loose fitting or a cut line. I think it is great that you are not getting any response, means no one has had any problems with the closed circuit.
11-23-2018, 10:18 AM
I find it kind of strange that we've heard crickets from someone (ie factory...) regarding this question. It is quite important that when the time comes, access information is available. Even if the answer is " only accessed from underneath and almost impossible to service" at least we know what to expect. Based on the pictures provided, it would seem impossible to access in an emergency outside of a service facility.....not good. Some kind of an access panel should have been built in by the engineers, one would think.
11-26-2018, 11:28 AM
Commercial Member
I'm not sure how strange it is. I was just giving time to see if any other user had the same question and/or answer for their rig.
I have not personally had anyone need to service the system. It is closed...so to check the level you should be able to look at the level in the tank. The fill level is etched on the side of the plastic tank. As for filling...you shouldn't need to, but if you do, there are some bulb style fill devises that can get fluid in there.
Easy to access? no. But part of that issue is that the need to access should be extremely low.
11-26-2018, 03:50 PM
Thanks Brian. It sounds like the answer is that the Equalizer system is pretty much not serviceable in the Isata 3. Looking at the pictures, they indicate the same. Here is hoping nothing ever goes wrong.
11-26-2018, 03:56 PM
Commercial Member
I don't know that I would agree with that assessment. If it needs to be serviced it can be, it is not easy to get to, but if need be we can drop the system. I will agree that I hope nothing ever goes wrong...I hope that for everything.
11-26-2018, 04:10 PM
I misspoke regarding not serviceable. Dropping the system out from the coach to work on it is certainly doable by the factory or a good dealer, but not something the customer could do at home or on the road. Just thinking out loud, a cutout somewhere to access it would be something to think about in the future. To think a solenoid or valve will never malfunction is probably not realistic. Just sayin..
11-27-2018, 01:09 PM
X2.
2019 ISATA 3 FW
LiFePO4 Upgrade
2013 Honda CRV Toad
