07-16-2021, 03:02 PM
Isata 3 Catastrophic wheel failure, RV Roadside Assistance Plan no help
Last month in IDAHO we had a catastrophic wheel failure in our 2020 Isata 3. While driving on I-90 both dual wheels on the driver's side came off without warning: just a big boom and then scary as hell until I regained control of the RV and navigated to the shoulder. Both dual wheels off of studs and tucked up into wheel well; I was driving on the disc brake and the steel plate of the leveling jack. No sign of lug nuts anywhere and no shimmy or vibration indicating pending loss of wheels before incident. All wheels had been changed and torqued about 5000 miles earlier by reputable local tire shop. Damage = 2 tires and rims destroyed; wheel hub needed replacement; RV body side at back of wheel well/generator access door pushed out, etc. Side Note, after incident we discovered Continental Fourseason Vanco tire had sidewall separation - second time we've had sidewall failure with these tires!
Good news is we were all safe (watch those Youtube videos on how to recover from a catastrophic blowout!). Bad News: (1) Forest River/SafeRideRV Motor Club Emergency roadside assistance not able to provide tow; (2) MBS took a week to deliver new steel wheel, wheel flange and lug nuts; (3) MBS only supplied one replacement wheel after two were ordered. I still need to find a replacement Alcoa wheel.
In over 50 years of driving I've never lost a wheel like this. Has anyone else had an unexplained wheel failure similar to this on their Sprinter?
07-16-2021, 03:16 PM
My guess is when the wheels were reinstalled 5000 miles ago they weren’t torqued enough or they were bound on the hub and gave a false reading when tightening. I’ve seen this before, especially with aftermarket wheels. When ever you have the wheels off in the future I would recommend re-torquing them within about 500 miles.
When our shop mounts aluminum wheels on a truck they test drive it than pull it back in the shop and retorque.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
07-16-2021, 03:20 PM
I can’t add anything, just happy you were not injured.
2019 Forester 2861DS E-450 sold
Camper less for now.
07-16-2021, 03:46 PM
Commercial Member
"were reputable"
07-16-2021, 03:55 PM
Every time I've seen a wheel come off it was related to the last person to install it .... regardless of reputation
2016 Dynamax DX3 - Big Blue
07-16-2021, 03:57 PM
Commercial Member
What did Roadside say? They clearly tow things, they do it for a living.
07-16-2021, 04:00 PM
My experience, and yes happened to me..
Re-torquing them within about 500 miles is a must.... glad you're okay
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
07-16-2021, 04:03 PM
Commercial Member
Agreed. One wheel is bad enough, but BOTH? Suddenly, leveling jack pad being low was a benefit. Might have saved some damage.
kudos to the driver for staying in control....and the "little jack pad that could". They get a bad rap...but he held strong!
07-16-2021, 04:05 PM
kudos to the driver for staying in control....and the "little jack pad that could". They get a bad rap...but he stayed strong!
Last I checked both dually were held on with the same lug nuts
07-16-2021, 04:07 PM
Commercial Member
This is why you are the last pick in kickball.
07-16-2021, 05:08 PM
Remember this, there is no such thing as a "reputable local tire shop".
I once almost lost a front wheel on a car that I just had new tires put on. They never tightened the lugs all the way. Luckly I started to get a shimmy before the wheel came off.
Now every time I have work done I check all the lugs before I even pull out of their yard.
07-17-2021, 12:24 AM
Any pics of what the sidewall separation looked like. Interested to know more as I and probably many others have the same tires.
PS: Anyone know offhand what the proper torque setting is for the lug nuts?
07-17-2021, 07:04 AM
Look in the owners manual. I believe the ram 5500 spec is 140-160 ft lbs. Just checked the tourqe on my tires 2 weeks ago, as many have said I don't trust anyone. Got the number from the owner manual.
2021 Isata 5 28SS Explorer
2017 Jeep Wrangler Unlimited Rubicon Recon
2017 Ram 3500 DRW
07-17-2021, 07:13 AM
Is your RV part of this recall for broken wheel studs announced last month?
https://www.forestriverforums.com/fo...ds-233240.html
2011 Flagstaff 831 RLBSS
07-17-2021, 10:20 AM
He has an Isata 3, so it would not be part of the Ram recall.
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
07-17-2021, 11:33 AM
Excellent that's why I asked as I don't know exactly what models are on which chassis.
07-17-2021, 01:56 PM
Responses to previous comments:
#8 - Yes, BOTH wheels separated from hub ring and were tucked up inside wheel wheel. At least they didn't become projectiles flying down Interstate. And the leveling jack "skid plate" was a life saver - I don't want to think about what might have happened if it hadn't held the axle/brakes above the pavement.
#11 - This was a locally owned shop that I've dealt with for years and is highly respected in the community. I doubt that a tire shop of less character would still be around as long as this one.
#12 Re: sidewall separation. See my post on previous sidewall separation.
https://www.forestriverforums.com/fo...-a-208700.html
#12 Re: torque - torque varies based upon whether steel rims or Aluminum rims are installed according to MBS charts. All lugs were re-torqued after being driven a few hundred miles.
#14 - Isata 3 was not a part of this recall although now I'm thinking maybe it should be.
Thanks all for your comments and concerns.
07-17-2021, 02:40 PM
I’m so happy that you were able to safely stop. I have had numerous incidents with sloppy/lazy technicians at supposedly reputable tire shops near me. It took Good Sam two days last summer to get someone able to fix a flat rear dually last summer near Lake Tahoe. No one wanted to take the call . The first person they called arrived ( 7 hrs. later) without an impact wrench and couldn’t remove the tire.
The supposedly reputable rv dealership who claimed their “best technician “ did my Sprinter’s very first oil service and blew up my engine with an improper filter…….
No, I don’t have a lot of faith in some of these so called professionals.
07-17-2021, 06:40 PM
Professional?
I don't know what that means. Wife says it has to be done professional, you can't do it. Guy at RV shop tried to hire me to work at his shop. Retired, don't want the grind anymore.
07-18-2021, 08:52 AM
Quite often I have found when someone is right (both wheels secured the same lug nuts) they are picked first.
Even 18 wheelers only one set of lug nuts per wheel.
2022 RAM 3500 Dually, Cummins engine, 4.10 rear end
2020 Forest River Model 36FL
