Originally Posted by Delco Bobby
Some jumper cables are almost useless. You should have the thick heavy duty ones. I learned that ages ago when my car wouldn't start with my jumper cables. A young lady came by and offered her cables. First time I saw ones that thick. Car started right up.
When it gets cold and motor oil turns to grease, it takes a LOT of amps to spin an engine. Even when you're running 5W-10 which most of us did, from October to April. In the 1970s, you couldn't even get 5W-10 except in the northern tier of states.
You needed the thickest cables you could get, copper, not aluminum, with cast jaws, not formed sheet metal. Many folks were embarrassed in the same way you were. When it got to -10 or below, the cables wouldn't immediately start the dead car. Often you had to connect the two cars, put the host car on fast idle, and go back inside for 10-15 minutes before the other car would crank.
Larry
(Everybody from Minnesota has a ten-minutes-from-death story, including me.)
