Old 08-06-2020, 04:25 PM   #1
drjeff44's Avatar
Isata 3 control panel not booting any help appreciated
The control panel screen not booting totally blank but here chimes come on when I turn kill switch to on not boot of screen any help appreciated
drjeff44 is offline   Reply With Quote
Old 08-07-2020, 09:10 AM   #2
Motorized GM
What model year Isata 3. What control panel?
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 08-07-2020, 09:19 AM   #3
drjeff44's Avatar
It is an Istata 3 CB and I am talking about the precision plex 7inch led panel
Old 08-07-2020, 09:20 AM   #4
drjeff44's Avatar
Isata 3 CBM
Old 08-07-2020, 09:22 AM   #5
Motorized GM
Ok, that helps. Pull the display, unplug it there and plug it back in.
There are times, that due to low voltage, coupled with voltage loss due to length of wire, it would cut out.
As a side note, that panel is just another switch...not the brain. So app control should still work along with the main switches and the main brain, not suggesting that is ideal, but everything should still be functional.
You can also try rebooting, turn off the battery disconnect and then turn everything back on. But unplugging and plugging back in seems to work in most cases.
Old 08-07-2020, 09:26 AM   #6
drjeff44's Avatar
I tried that and did not work called precision circuits and they wanted an email with a picture of the back of the board. I hope that under warranty. I will keep you posted. Thanks
Old 08-07-2020, 03:46 PM   #7
I had similar situation where Precision plex panel would not reboot even when using battery disconnect. With help from Precision Plex, I fixed it by unfastening panel and disconnecting control wire on back of unit, waiting a while and plugging back in.
Has worked perfectly since.
I think total power to panel was not removed thru battery disconnect switch!
geneandjan is offline   Reply With Quote
Old 08-07-2020, 03:53 PM   #8
drjeff44's Avatar
Thanks for the help. I tried that but to no avail. They are sending me a new board I will keep you posted the good news is they are plug n play so should be straightforward
Old 08-07-2020, 04:38 PM   #9
The Wanderer2's Avatar
Wow, had the same problem this week on my Berkshire and had to replace the screen too. I hope this isn't going to be a reoccurring problem.
2019 Berkshire 34QS
The Wanderer2 is offline   Reply With Quote
Old 08-07-2020, 04:46 PM   #10
milkman55's Avatar
This issue has been reported a number of times, but Precision Circuits has always responded promptly with a replacement screen. I have needed to call them once on another issue and they were very good to work with.
2021 Isata 5 30FW
2014 Honda CR-V
milkman55 is offline   Reply With Quote
Old 08-07-2020, 05:10 PM   #11
They responded to my issue the same day I contacted them. I'm extremely pleased with their handling of my replacement screen.
2019 Berkshire 34QS
