You may want to reverse the direction of the zipper on the insulated cab curtain, i.e., zip down to close, zip up to open. That way you don't have to put the two sides together to start the zipper and if it is unzipped half-way it is open at the bottom, not in the middle.
__________________ If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Absolutely not...then you wouldn't have to buy a new unit to get it
It will eventually be a part number in the system. I'm not sure we have it there yet, as we are waiting for V1.2. It does velcro onto tabs that are built into the wing wall material, but I'm sure a few screw on velcro tabs would work.
Too funny!
I look forward to adding it in the future...but who knows, maybe I'll trade up to the Freedom Edition???
I don't think we build enough of the 24RW to justify the engineering time...but who knows what the future brings. We will have a 2nd floor plan for the Freedom Edition, should see it in the spring.
I would think the RW may appeal to longer stay dry camper (which is what this is intended for) as it gives you a much much larger outside storage spot for extra gear.
Xantrex put together a nice little marketing piece.
After I had it out, they came back and tweaked the batteries to draw power from the 2nd alternator as well as the extra on the first. They got it up over 300 amps at highway speed.
First one I thought shipped, but another should be shipping this month
New Isata 3 Freedom Edition Floorplan featured on Camper Report Show
This week we take a quick tour of the new Isata 3 by Dynamax! John gets all the details and a look inside the unit. (The video review with Brian Clemens starts at 26:07)
You get the tour with that video. here is the 2D version. We are making a couple of tweaks to the production version (mainly to get more room in front of the sofa when the slide is in)
Curious if you will be debuting the Freedom Edition 3 Series anytime soon at any RV shows in the Los Angeles area?
Both Dennis Dillon RV and Conejo RV will be getting one for stock (24FW Freedom Edition) within the next couple of months. Neither of these dealers have any shows in the future in the LA market.
Brian,
Will the prototype 24SSSFX be on display at the FROG rally?
When can I start encouraging our dealer, Barrington Motor Sales RV, to get one ordered?
Is there a hidden 'code' in the model name?
Mike
Thanks.
What is the size of the Murphy bed and what is the model called that has that configuration?
2017 Isata 3 24FW (Purchased Feb '20)
I think we are only going to have a 5 series at the FROG Rally, but I can ask sales about the 24SS instead.
24SSSFX...there is sort of a code.
24 is roughly lenght. SS is super slide, SF is single fuel. X is more for Xplorer model, which this was supposed to be like, but I called it Freedom since it was quite a bit different from the Xplorer.
Murphy bed is 60x75 I believe.
Due to the extra length of the 24SS, it will ONLY be available in the Freedom edition since it is lighter than the normal unit. It is still not where i want it, so we're working on a few tweaks. I would like it to be at least 1000 lbs CCC.
