Our step on a 2017 SunSeeker MBS 2400W failed last year. We really use our RV (58000 miles, about 24 months on board), and regularly sprayed the mechanism with WD40 Lithium Grease.
I tore into it, and removed the motor and gearbox. The step needs to Be retracted for easiest access, and is plenty hard to reach unless the RV is up in the air. The bad news was that the bolts that hold the gearbox in place are not secured in any way to the plate above it, and two of them “disappeared”, pushing through that plate... this necessitated removing the entire step assembly, a real PiTA!
FYI, that gearbox is pretty solid. The motor is really easy to remove, and worth replacing first before attacking the gearbox (and possibly ending up having to take off the whole step system). Also, the motor is much cheaper than the gearbox, and readily available from several sources on line.
Hope this helps!
Bob.
