Old 06-23-2021, 01:10 PM   #1
jneum525's Avatar
Isata 3 - Shower Door Latching Woes
The wall side where our shower door magnet latches has a rather pronounced convex curve to it along the wall from top to bottom. I'm sure it has always been this way. Certainly as long as we have owned the coach. When latching the shower curtain, the magnetic latch will only latch at the top half or the bottom half as the straight edge of the shower curtain does not match up with the convex side at the wall. I have found it best to try and latch the door on the bottom half in order to prevent water from leaking out of the bottom of the shower.
Curious if anyone has a similar problem and a potential fix? Would very much like to have the door latch from top to bottom.
PS: I know the pics are hard to look at sideways. I needed to take the pics in portrait configuration. The 2nd pic has the door latched at the bottom half and the 3rd pic latched at the top half
ID:	257666   Click image for larger version
ID:	257667   Click image for larger version
2017 Isata 3 24FW (Purchased 2-20)
jneum525 is offline   Reply With Quote
Old 06-23-2021, 02:01 PM   #2
Motorized GM
fixed it. If you take pics with the iPhone, you just need to make sure you edit it before posting...even on the phone if you just crop it, it normally takes care of it.
I would try running a screw into the middle to see if you can draw that back (if no backer in that spot, likely won't work), or shim out the top and bottom a bit, seal the difference. Might need to cut the head rail down if that is what is long. Or shim the magnet in the track on the wall side...or put in positive latch (like hook and eye)
Lots of ways to skin that cat.
ID:	257673   Click image for larger version
ID:	257674   Click image for larger version
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 06-23-2021, 02:06 PM   #3
Bill Davis's Avatar
If I take pictures with my IPhone in the horizontal position the pictures post straight. Itís only when I take them in the vertical position that they post that way. Hope that helps everyone.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
Bill Davis is offline   Reply With Quote
Old 06-23-2021, 02:54 PM   #4
jneum525's Avatar
Thanks Brian. Always appreciate your help. Will take a look at which option might work best when it cools down a bit. Also thanks for the tip on the pics... You are a wealth of knowledge...
Old 06-23-2021, 03:20 PM   #5
Kanadian Kamper
kenandterry's Avatar
We donít have a Dynamax, but it looks like the shower stall in our Sunseeker is a very close copy. Hereís the mod I did to give the most elbow and shoulder room, and eliminate shower door malfunctions.
SorryÖ..in order to capture everything, my photos are in portrait vs landscape too.
ID:	257682   Click image for larger version
ID:	257683   Click image for larger version
Ken and Terry
2018 Sunseeker 2430S-CD
and if we ever need it, can be pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
door, show, shower
