Fuse?
Originally Posted by Izzy3
Any help would be appreciated.
2017 Isata 3 (purchased new in 2016) with Bigfoot stabilizer jacks mounted in the center of rear differential.
Jacks are stuck in the down position. No movement or sound when pressing “retract” or “extend” on switch.
Batteries show good voltage using multi meter.
Also showing good voltage through Buss circuit breakers mounted in chassis battery compartment under step.
Emergency brake is on.
Am I missing something? Is there another fuse or breaker somewhere that I haven’t thought of?
Coach is my driveway, but I would like to move it.
Any help or ideas is appreciated prior to me calling a mobile tech.
Be safe
You didn't mention looking for and checking a fuse.
(Sorry, I don't know where it would be on your unit.)
Larry
