01-06-2019, 02:15 PM
Isata 3 water leak
I picked up an i3 in Elkhart a few weeks ago now. At the time I noticed a drip right over the face of the inverter. Pump was also kicking on momentarily so I was looking for the problem. The next morning I had it back to the shop which did the PDI. I showed them this and s couple of other things. Well, I got it home in the heated shop and still a drip there and also down the lines where the low valves are from above the valves. Nothing wet inside that can be accessed. The dynamax service center here is not real convenient for me plus it's January in MN. I just thought I'd put it out there if anyone had an idea where it's at? I've laid underneath and am afraid it will be hard to get to.
01-06-2019, 05:21 PM
You don’t say what floor plan you have. On mine the kitchen sink and the Truma are in that area. I would look there inside the cabinets.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
01-06-2019, 05:32 PM
It's the full wall slide floorplan. I did look all thru the truma and everywhere inside, and took off access panel to pump. There is no water inside. I suppose it's one of many fittings and as we know a drip one place likes to travel.
01-06-2019, 06:48 PM
Is there an outside shower in that area? A lot of people have had loose fittings there
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
01-06-2019, 07:15 PM
Maybe you've already done this, but you can remove the drawer under the cooktop to get a better look at the plumbing behind the truma.
2017 Isata 3 24FW
2004 Jeep Wrangler
01-06-2019, 07:25 PM
The outside shower is on the other side near the Anderson valve. I stuck my finger in the blank hole and felt around the back of the Anderson valve. It is dry. I am going to put another valve on the base of the outside shower hose though..I can imagine those shower handles jiggling open!
01-06-2019, 08:48 PM
Try this ^^^^
Lots of connections behind the kitchen drawer in between the Truma and the kitchen drawer. This is where the bypass valves are located.
2021 Isata 5 30FW
2022 Ford Ranger Tremor 4x4
(Previously owned a 2017 Isata 3 24FW)
01-06-2019, 09:37 PM
Commercial Member
Drawer under the stove can get you a good look...there is also a false floor on the kitchen base. There are likely some T's under there for the risers.
01-06-2019, 10:06 PM
Didn't notice a false floor, that sounds like a possibility I will look into tomorrow! Thanks
