01-29-2020, 12:55 PM
#61
Thank you.....Those lights would seem to be fine for my 2019 30FW then. I saw a few comments on Amazon of a flicker problem but you have "Real World" experience. I will order a set of both low and high beam.
Tom in Ohio
2019 Isata 5 30FW
01-30-2020, 05:57 AM
#62
Figured out a way to attach a sewer hose carrier.
-Brian
2020 Isata 5 30FW 4x4
2019 Jeep Grand Cherokee Summit
01-31-2020, 12:44 PM
#63
Looks good. I had added one of those to my Isata 3. I guess the hose storage on the inside of the Isata 5 door is not sufficient for say the Rhino hose and fittings? We pickup our Isata 5 sometime in the next few weeks, so will be starting down the mods path soon.
2021 Isata 5 30FW
2014 Honda CR-V
01-31-2020, 04:30 PM
#64
Commercial Member
No, maybe it wasn't, but we added a sewer hose holder to the door and it does fit, I think a 15' Rhino, with fittings.
01-31-2020, 04:32 PM
#65
Where's that at? I'd like to see it.
01-31-2020, 04:43 PM
#66
Neither of my hoses with fittings fit in that storage area as it's not wide enough for the fittings. I guess BClemans fixed that now with a new area. I have my hose in a plastic container w/ lid.
01-31-2020, 08:22 PM
#67
I have the RhinoExtreme hose and the carrier on the cargo door only holds a 5 ft. piece. You can put 15 ft in the carrier I added.
The center supports are pipe hangers from Home Depot, that I painted black.
-Brian
02-01-2020, 08:18 PM
#68
Shunt Cover
Shunt Cover...
https://www.amazon.com/gp/product/B07QDQRX7P
Dozen to choose from. I liked this one because it already had the cut-outs and grommets and had the ears for attaching to the side wall. I removed the terminal bar. Fit over without having to relocate the shunt.
-Brian
02-25-2020, 08:37 AM
#69
Magne Shade...
Awesome company to work with. Great customer service.
-Brian
02-25-2020, 08:40 AM
#70
Crossfire...
Chrome zip ties.
-Brian
02-25-2020, 09:01 AM
#71
WeBoost...
Added a couple of 12v sockets behind the driver's seat to power the WeBoost and charge the Dyson. Added a 12v switch to turn it on and off when needed.
(I suppose I have given up my right to complain about the appearance of keyless transmitter. )
-Brian
02-25-2020, 11:04 AM
#72
Commercial Member
lol...we agree.
#73
Commercial Member
Originally Posted by fstclyz
These GoPower 100w panels have a max of 5.68 amps (best case conditions) per panel. We rarely see max output but max amps then for 5 panels is 28.4 amps. The controller is rated conservatively at 30 amps, really not to exceed 35 amps. That's why most of us stick to 5 panels totaling just under 30 amps.
FYI, we don't have that luxury as we have to go by what the panel is rated at. As I recall they re rated at about 10amps. So we can only put 3 (thought Go Power says 4 officially)
02-25-2020, 11:20 AM
#74
I called Go Power prior to install to ask about the OEM controller capacity because I wanted to add FOUR panels. They did not recommend 600 watts with that controller but said 5 would be totally fine.
FWIW - at its highest output in pretty ideal conditions for this time of year in the north east I have only seen the 5 panels produce 19.3 amps. On decent days they average around 13 amps.
-Brian
02-25-2020, 12:01 PM
#75
Commercial Member
It's your rig, you can do what you want. I'm just saying by code its rated at 8.3-ish amps per panel??? So when the electrical engineer lays it out, we have to size wiring and controller based off rated output, not actual. Thus, we end up with 3 panel max.
On the 28SS, we did an 800 watt system, but had dual 40 amp MPPT controllers.
02-25-2020, 01:30 PM
#76
Crossfire Install
So did you drill out the center of the hub cover like was discussed in the Crossfire thread?
We pickup our Isata 5 on March 11 and I am making my mods list. I definitely think this is worthwhile.
2021 Isata 5 30FW
2014 Honda CR-V
02-25-2020, 02:54 PM
#77
Yes. I did almost exactly the same thing as sseaner posted in his CF thread.
5-inch hole saw is perfectly sized for the hub caps.
I used this to touch up the edges:
Molotow Liquid Chrome Alcohol Pump Marker, 4mm,
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
-Brian
02-25-2020, 02:56 PM
#78
...but had dual 40 amp MPPT controllers.
Exactly. I could have upgraded the controller to add more panels but I would have had to relocate it and thought that was more trouble than it was worth.
-Brian
02-25-2020, 07:25 PM
#79
CORRECTION: 6-inch Hole Saw - not 5
-Brian
02-27-2020, 10:37 AM
#80
2019 Isata 5 30FW
Brian - What kind of plate did you mount the WeBoost on, and where did you make entry into the unit, did you just drill a new hole or use existing looks like you have some kind of special cover at cable entrance into inside the unit. I am assuming the caulking is just dicor self leveling sealant?
