Isata 5 30FW Overhead Bedroom lights came on on their own?
We're driving home from Maine and pulled into a Cabela's to spend the night. When we arrived the overhead bedroom lights were on and they are not responding to the switch. I press the switch and it turns blue to indicate the on state and when I turn the switch off and the lights stay on. Same with the PP panel. Both indicate on/off but the lights are not responding. We turned everything off before we left.
I tried the master switch and nothing. I tried disconnecting the batteries at the cut-off switch but once I turn it back on the lights come on again. I checked the data cable to the switch but it is one cable for both lights - Bedroom Ceiling and Bedroom Overhead. Bedroom Overhead continues to operate correctly. The lights are flickering every so slightly.
Any thoughts on getting them turned off until we get home? Should I just pull the fuse?
Outside of the immediate need to turn off any thoughts on the cause and possible solution to correct?
-Brian
2020 Isata 5 30FW 4x4
2019 Jeep Grand Cherokee Summit
