I've read through the post from RedSteelManUSA which is becoming an older post so I thought I'd start it again. I didn't see any links for aftermarket kits on that thread.
I would like to add a few inches in the rear especially. Fairly small drainage areas in BLM land the rear can hit. I'm not looking to do four-wheel-drive trails just easy boondocking can cause rear-end damage. I'm not looking to spend the money on Kelderman.
Cloth11 stated they did leveling blocks and a front-end leveling kit (links?). Redsteelmanusa, did you end up raising your I5?
I'd like to use this thread as posting the links to what others have used to raise their I5s, rear, and front. Again, there are some really good threads on Kelderman so let's don't go that direction on this thread.
Has anyone used the
lift blocks from this company? How about using those lift blocks with the
Firestone air bags? Thanks everyone!
