Isata 5 Generator Access Panel Install Suggestion
After a little common sense and searching on this forum I discovered the access panel for the oil fill for the generator. I was ready for my 50 hour new use change! I put out the dinette slide (thanks to the new module sent to me earlier this week!) and crawled underneath with my phillips head screw driver. Suckers wouldn't budge. Not one of the 4. And Ive got a good grip and was leaning into it with my shoulder. I carefully used my drill press and was able to get them started without stripping them. Interestingly, the screws holding in the trim nearby moved easily. I suspect an enthusiastic employee put them in with a drill press after drilling the holes and never took them out. Suggestion, since these screws are meant to be removed multiple times - have the crew take them out after install and then put them in by hand. No way are those Elkhart, Indiana boys able to hand screw as tight as these were.
Jim
2019 Isata 5 DS
Jeep Wrangler Sport Unlimited Tow
