Old 11-25-2020, 10:57 PM   #1
Isata 5 microwave first time use
We just used the microwave for the first time and 15 seconds reheating food it stopped working. No power it seems and the circuit breaker is not tripped. Reset the breaker and still no light or sign of power to the microwave oven. Plan was to use the oven for the turkey tomorrow. Plan B not sure yet.
msusslin is online now   Reply With Quote
Old 11-26-2020, 06:30 AM   #2
Bill Davis's Avatar
I’m guessing your plugged into shore power. Did you make sure you have power at the post? Did you try it with the generator on?
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
Bill Davis is offline   Reply With Quote
Old 11-26-2020, 06:34 AM   #3
nomad297's Avatar
I don’t know if this applies to the Isata, but if you have an electric fireplace and you are using it, there could be (some sort of) a switch that automatically turns one off while you are using the other. I know a lot of 30amp RVs are setup this way. Again, no idea about your RV.
Bruce
nomad297 is online now   Reply With Quote
Old 11-26-2020, 07:04 AM   #4
TrailWayz's Avatar
Seems obvious - but did you check the plug in the cabinet overhead?
Our microwave was unplugged when we received our I5 and the cord had not been pulled all the way through to the upper cabinet. Maybe yours is just loose since it worked briefly?
-Brian
2020 Isata 5 30FW 4x4
2019 Jeep Grand Cherokee Summit
TrailWayz is online now   Reply With Quote
Old 11-26-2020, 11:56 AM   #5
Thank you for your feedback. We found the problem. The microwave was plugged into a search protector power strip which tripped. We plugged the microwave into a wall plug and all other plugs for the TV equipment into the power strip.
Old 11-26-2020, 12:08 PM   #6
Was this motorhome supplied from the Dynamax factory with the microwave oven plugged into a power strip?
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 11-26-2020, 01:37 PM   #7
Not sure but I suspect that the dealer, while installing the Dish Wally, might have done that.
Old 11-27-2020, 05:42 PM   #8
Motorized GM
We don't provide power strips.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 11-28-2020, 11:39 AM   #9
I would have been surprised if that cheap power strip would have come out of the Dynamax factory. How should extra entertainment equipment be plugged in with only 3 outlets in that cabinet? Is there a small power source distributor available the size of the DVD which would help to keep a clean installation.
first time, microwave
