Originally Posted by wachorver
Our 2019 Isata 5 30fw awning goes in and out sporadically when using Precision Flex control. No manual came with coach nor in digital stuff. Who is manufacturer and how can I get a manual with troubleshooting info. ?
Paper manuals are always shipped with the coach.
Digital flash drive is also included...some people mistake it for "just a key chain".
Lastly, if you bought used and have neither of those they are ALL, also available online in the digital owners manual.
We are in the process of updating all of the manuals...but here is a link to the 2021 which has the Carefee awning. When you go through the manual there will be PDF's, links and videos off the the right that are contextual.
https://forestriverinc.help/#/dynama...0-9B7635B48F94
Once we update, all of those will be available in a single folder so you don't have to root around in the owners manual to find the appliance manuals.
Though all the awning does is go in and go out. So if it is working sporadically, I would agree it is more likely a multiplex issue, or....
If you press the button for one second and release, it should automatically extend. However, if you press and hold the button, then it puts it in "manual mode" so it will stop when you let off the button. That way you can only put it out so far. That may seem sporadic if you don't know that it can do that.
