Old 09-27-2021, 02:43 PM   #1
Rrzasa's Avatar
Isata 5 Rear Shocks
Anyone replaced the shocks in their Isata 5?
I'm looking to replace them and contacted Marcus at Koni to get the correct part number for their FSD shock and he tells me that they do not make one for the Ram 5500.
What are people replacing their shock with? Bilsteins? Monroe? KYB?
Or just the OEM Ram shocks?
Rob & Rosanne Rzasa
2017 Dynamax Isata 5 36DS
Towing 2005 Honda Big Ruckus
Go Gators
Rrzasa is offline   Reply With Quote
Old 09-28-2021, 10:30 AM   #2
I had my front driver shock fail after 4 months. Replaced it with a factory shock
2021 (Dec) Dynamax Isata 30 FW Xplorer
toshu is offline   Reply With Quote
Old 09-28-2021, 11:44 AM   #3
Norwood Auto Italia
Liquidsprings. Makes a huge difference. The shocks are not the problem, its the spring rate needed for an overload situation as spec'd by Mopar.
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2021 Isata 5 28SS Explorer
vlamgat is offline   Reply With Quote
Old 09-28-2021, 01:17 PM   #4
Liquidsprings? Did you do the whole setup $16K cost.
msusslin is offline   Reply With Quote
Old 09-28-2021, 01:50 PM   #5
Rrzasa's Avatar
Thanks for the suggestion but I've had airbags installed last year and it was riding wonderfully with the bags pumped up to 50PSI, now it rides rough and I think the shocks may need replacing.
Rob & Rosanne Rzasa
Go Gators
Old 09-28-2021, 03:20 PM   #6
Norwood Auto Italia
Air front and LS in the rear.
Old 09-28-2021, 03:46 PM   #7
Silly question
Silly question, but did you check to see if the air bags are still at 50 psi?
Larry
Larry-NC is offline   Reply With Quote
Old 09-29-2021, 06:33 AM   #8
Rrzasa's Avatar
Yes sir, still at 50.
Replaced the Continental Tires with 6 new Michelin's and the ride is better but still hear more creaking that I'm used to after 4 years.
Checking to see which of these two I can get this week and replace the rear shocks and see if that is the problem.
Bilstein 24-238533 4600 Series Shock Absorber
Monroe 65547 Rear Gas-Magnum 65 Shock Absorber
Rob & Rosanne Rzasa
Go Gators
Old 09-29-2021, 07:07 AM   #9
Norwood Auto Italia
How did you ascertain that pressure? Are your air bags user adjustable?
Old 09-29-2021, 08:12 AM   #10
Rrzasa's Avatar
The company that installed them advised testing 40, 50 and 60 PSI and determine what seemed to be the most comfortable. We tried all the recommended pressures and settled on 50PSI.
It has performed well till the last trip as we had a 4 month period when the coach just sat unused.
Yes, each bag has a separate fill port so I can fill and adjust as needed.
Maybe I need to try changing pressures to see if that has any effect.
Rob & Rosanne Rzasa
Go Gators
Old 09-29-2021, 08:23 AM   #11
Norwood Auto Italia
Please take a picture of one of your fill ports. Mine are inside the wheel well plastic liner and quite unreachable without removing the wheel. That is unless there are others somewhere else?
In any event, the bag pressures are set by a compressor and a tank mounted underneath just behind the transmission. So I do not know how/why a fill port would be used except in the event the compressor failed? I have not found any way to alter the pressure the compressor references. Nothing in the OM and the factory tells me there are NO user settings.
