I'm not sure it was too lengthy, but this is the first I saw it. New posts don't out signals so it might just take a little time.
The Ram chassis started using CANbus for its signals. it is not an analog signal like it used to be so we had to use the Intermotive to read the digital signal and then send it to the camera. So if the chassis is off, there would be no signal. Key needs to be on.
Personally, I would eliminate any triggers IF you can turn the mode to show all (3) screens (like we do today). OR, use the AUX switch's to send a signal for the right and left signals.
