Originally Posted by mbzdiesel
i had the generator on for hours, the battery gauge on the solar panel showed fully charged when i shut the gen off. after this it seemed like the solar or batteries couldnt keep up as they went dead within an hour during a sunny day.
i only have 2 batterys that came with the unit, i have a magnum inverter not Xantrex. yes i was referring to setting on the inverter panel
What I would look at for this is:
I would look at the charging current going into batteries to see that they are getting charged.
I would look at the charging current from the solar to make sure it is providing current during charging and use.
I would monitor the current when you are unplugged/generator off. Turn inverter off and look at battery current to make sure there is not something that is drawing current. If nothing there turn various things on and off to see if the current is reflected in the monitor.
If the batteries are good and fully charged you should see a large current draw to pull them down that quick.
I don't know about the magnum inverter settings. But with two batteries you should have about 100 amp hrs usable before voltage gets too low and cuts out. The 100 amps usable is at a relatively low rate around 10 amps.
Check what the cut out voltage is. It may be set too high.
Not sure what you solar adds but maybe 10 amps.
Look at battery current. Turn refrigerator off and on to see change.
Our refrigerator is rated at 6 amps at 120V so it is possible for it to draw around 60 amps at 12 V from the battery through the inverter. I have never seen anything close to that on our coach.
Plug a tea pot/coffee maker in or run the microwave for 20 seconds and watch the current. Either should spike the current to around 100 amps. Doing this for an extended period time will deplete your batteries fast.
Need to look at settings on Magnum and check that the charger is charging the batteries at high enough rate to charge them in about 4 hours. With 2 batteries rated at 130 amp hrs each the initial charge current should be around 40-50 amps.
If charger is working then may be bad batteries.
