What is everyone else running their tire pressure at for their Isata 5? I can't seem to find a loading/pressure chart for the Continental tires - just a max load/pressure.
For loading, with the 5 of us and a 1/3rd tank of Fresh Water, we're just under the axle limit on front (a bit under 7000 lbs), and around 12800 on the rear axle.
Hmm, if I go percentage-based, I get about 97psi on the front axle - I had been figuring on going about 100psi, so that sounds about right. On the rear, percentage would put me at about 102psi, so I'll probably round that up as well, to 105.
