Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-29-2021, 01:46 PM   #1
Norwood Auto Italia
Isata 5 wiring/current limitation?
From the FB page - a question was asked as to whether 2 X 1500 watt heaters can be connected to the 15 amp sockets without tripping the Gfi?
Anyone attempted this? I don't believe it can be done because both 15 amp sockets feed through a single 20 amp Gfi and show up on Leg 1 of the Firefly panel?
Is there a way to get access to the unused Leg 2 when there is 50 Amp/generator power and the AC or Heat Pumps are not running? I do not think so from my reading of the wiring diagram but ....
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2021 Isata 5 28SS Explorer
vlamgat is offline   Reply With Quote
Old 11-29-2021, 02:36 PM   #2
Add a breaker on leg 2 and wire an outlet from it. I plan to do exactly that with a 30amp socket and breaker so I could export power to a 30amp RV if need be (such as my in-laws traveling with us in their RV) as well as some other outlets on the inverted side as well for other purposes.
Phreak480 is offline   Reply With Quote
Old 11-29-2021, 02:47 PM   #3
Norwood Auto Italia
What about the Gfi, is it isolated from Leg 2?
Old 11-29-2021, 08:01 PM   #4
Desert Boat's Avatar
Per the "standard" Isata 5 120 V diagram, all the domestic 120V service comes through the inverter, which is on leg 1, so that provides a hard 30 amp limit on those items.
But some 28ss (I believe this includes your coach) have a separate breaker on line 2 for the outside kitchen stove. So the FB OP could add a breaker feeding a separate outlet from leg 2. This diagram shows that configuration.
Name:	Screen Shot 2021-11-29 at 8.00.27 PM.jpg
2021 Isata 5 28ss 4x2 / 2020 JLU Rubicon
Prior: 2016 Lance 1995 / Ram 1500 Eco Diesel
2012 Lance 1575 / 2015 Jeep JKU Rubicon
Desert Boat is offline   Reply With Quote
wiring
