FYI:
Slideout cables are now shortened and this has definitely improved the tire pressure reporting! Now, the inner dualies are the most responsive I've experienced in the last two years / 20K miles. I am currently in the process of fine tuning the location of the receiving antenna (much closer to the floor). Presumably, I will now be able to use the dinette seats for storage?
In addition to a minor reduction in weight, I'm inclined to think taking that much extra wire out of a DC circuit might be helpful during its operation if voltages are marginal?
HTH,
SParkie
Details for those interested:
Lippert would not provide any "proprietary" details about their cables. No, worries, my local electronics shop recognized the connector as a molex MINI-FIT JR. Connector. They even had a nice kit of receptacle, plug, and contacts. I bought two kits WMF-3903PRT Walden Electronics. (~ $5 ea)
1pc Receptacle 39-01-2060
1pc Plug "Housing" 39-01-2061
6pc Male Contacts 39-00-0041
6pc Female Contacts 39-00-0039
Small challenge:
The contacts are rated for 8 AMPS 18-24 AWG, but two of the wires in each cable are 16 AWG. Makes sense as they power the slideout motors. Turns out molex makes contacts that will provide proper crimping for 16 AWG wire. I ended up ordering a small bag of 39-00-0078 from TTI.com (could have used Arrow.com or one other distributor). These contacts fit the housing, but have slightly larger crimp "wings" to hold the conductor. In my mind, this is critical to get a properly formed crimp that passes the 30 lb pull test required for 16 AWG.
Big challenge:
Getting a crimp that conforms to molex specs.
IMO, the existing connectors were non-confirming and that explained why it was virtually impossible to de-pin the existing harness.
My Wirefy open barrel die was too large to properly crimp these contacts. That said, I ended up ordering a molex Hand Crimp Tool (63811-1000). Getting good crimps took considerable practice! The 22 AWG is quite different from the 16 AWG in more ways than one. I found the crimping wings that hold the insulator were too long on each and shortened them somewhat to obtain conforming crimps. Good thing I had some extra contacts to experiment with as well as to perform the weight test. It is the recommended way to confirm your crimp is satisfactory, but it is a destructive test (contact gets crushed).
If you shorten these cables, practice, practice, and test before attempting. Disclaimer, I was a Radar Tech in the military and have repaired numerous cables, but that was more than a few decades ago
. Each wire gauge required a different technique. Spent hours practicing and testing. Once qualified and confident, the actual shortening process took less than an hour to complete.
There is helpful downloadable info on molex.com including their Quality Crimping Handbook (63800-0029).
I also ordered a bag of 39-00-0039 to make sure I had more than enough contacts for both gauges.
