Originally Posted by Orangecrush
I get on the road and about 50 miles into it, I stop at my local truck stop and check my fluids and tire pressures as I always do.
The inner right tire had no air in it at all. The bead was broken off the rim and couldn't hold pressure. I called a mobile tire repair place and they said they wouldn't be able to do anything because it was run flat (technically, it wasn't)
So I used the leveling system, raised the tires off the ground and put air in it. It worked just fine and I monitored all weekend and never had a problem (I suspect the valve stem extension leaked) Good thing I installed those TMPS sensors on all the wheels... they're annoying but it works.
1) I wanted the tire taken off, inspected, replaced if necc. or at the very least tell me what was wrong with it. It hadn't been run flat, I'm pretty sure the air leaked out while sitting at the dealer.
I thought about doing that but instead, I used the leveling system to get the tires off the ground which I figured would at least leave the bead equally spaced all around the wheel. I had to drive to a different truck stop because the one I had stopped at had literally no air pressure.
Point is, it worked with enough pressure and so far, still seated...
Mark
Mark, I'm still "very" concerned about this tire. You have stated previously that you think the air leaked out at the dealer but also say you drove it at least 50 miles from there....which is what we in the TIRE business do consider running it while on flat (for awhile). You may be thinking of something else with the terminology of "run flat". We in the biz say it was "run flat" if you continued to drive with no/or very low air pressure.
I just am scared for you over possible internal damage from running this tire while it was flat. I could not trust it, and strongly suggest you have it checked out (ie dismounted).
