Originally Posted by sconnors11
Why did you change? Which tread lite model was used? Where did you order from? What's the difference in step height to the ground?
Thanks,
Sean
Step heights are approximately the same , the old steps needed paint and the mechanism needed some work so I decided to upgrade ~ I could not be happier, they were sourced thru Amazon and installed I really like the slide motor mechanism and the non slip aluminum steps as well as the led light!
