06-29-2022, 05:36 PM
Leaking from a light??
Accidentally posted in the wrong forum, sorry all.
'21 Dynamax Force HD 37BH
06-29-2022, 05:46 PM
I would start my search on the roof and try to determine if that is the source of the leak. If the answer on the roof does not solve the problem, I would take the light down and try and see where the problem may have originated. If nothing is on the top side of the light, I would assume that the light may be bad and the source of the leak. You may of had a leaking capacitor or something or the control board for the LED light.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
06-29-2022, 05:47 PM
Hi all,
We FINALLY got our baby back from service after five long months and took a trip last weekend- YAY! Feels so good to have our home on wheels back.
But...
We were making the bed when we arrived at our campsite a few days ago and noticed a stain on the mattress pad. A bit of searching around and it appears there has been some drip-stream from the light fixture directly over that spot. It's brown tinged, the spots on the edge of the can lights are brown and a bit sticky feeling.
I honestly don't even know where to start. Do I pull the can light down? Should I check something on the roof?
Any ideas?
Thanks, as always.
-Melanie (and Les)
06-29-2022, 06:01 PM
You can pull down the light, it just has two spring clips holding it in place. Might be able to get some light up to see the bottom of the roof. Might not see anything as there should be insulation in the space between the ceiling and roof. I would go up on the roof and look at the caulking around all the roof penetrations in the area above the light.
2021 Isata 5 28SS Explorer
2017 Jeep Wrangler Unlimited Rubicon Recon
2017 Ram 3500 DRW
06-29-2022, 06:13 PM
Is there a vent , AC , skylight close to that light ?
06-29-2022, 08:08 PM
yep. almost right next to it. Guess I've got some investigating to do tomorrow.
thanks. I'll do some investigating tomorrow.
06-30-2022, 07:20 AM
Commercial Member
9 times out of 10, its a skylight. Those are plastic. There used to be a company that made replacements with a metal frame, but I haven't been able to track down that website again.
I think I would change to them in a heartbeat.
If "Search this Forum" does not yield an answer, please post questions as a "New Thread" (instead of sending a private message) so that others can benefit from the answers. Use Private Messages for sensitive information only.
Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
06-30-2022, 07:33 AM
Thanks Brian. I'll start there.
06-30-2022, 07:39 AM
I think a great option would be one that says no skylights on the order forms.
Would stop the heat problem and less chance for leaks
2014 3051S - First RV for us
2022 DX3 RB on order
06-30-2022, 02:03 PM
Here is the link to the ones I believe you’re thinking of.
https://maximskylights.com/
I replaced the skylights in my 2017 Airstream (pre-Dynamax) with two of them. They are the bomb. Good people to work with too! Two or three layers, metal casing, pick your tint, keeps the heat out without the use of shades or cushions.
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
06-30-2022, 02:06 PM
Commercial Member
that's the one, thank you.
06-30-2022, 03:35 PM
Only issue with the Maxim skylights is they mount over the Airstream flange that goes around the opening. As they say, “like a lid on a shoebox”. Maybe a running product change in the future on Dynamax units…build an aluminum flange around the skylight opening, then have Maxim supply these bad boys for OEM installation. No more leaking skylights!
Joe & Cynthia
06-30-2022, 04:04 PM
Well this sucks.
Take a look at what we found.
Um... RV sealant I guess?
06-30-2022, 04:31 PM
That’s on a 2021 model?
Joe & Cynthia
06-30-2022, 04:44 PM
clean it Acetone then dicor self leveling
06-30-2022, 06:24 PM
If your just going to seal it with Dycor I would stop drill a hole at the end of the crack to keep it from continuing to spread. What’s everyone think about that?
 2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
06-30-2022, 06:35 PM
That is a darn good idea!
Also chamfer the outer edge of the hole with a bit a couple sizes larger. Do just the very top of the hole, not much.
Cross-threading works better than blue loctite.
06-30-2022, 07:21 PM
yep. 2021 Force 37 bunk model
06-30-2022, 07:25 PM
Thanks Mr. M, Bill Davis, and Capacitor.
That'll be our next step.
Should this fall under warranty? The roof is barely a year old.
