Unless you already checked the level on your Equalizer System, you need to get a 4 ft level and check to make sure the Null Point is set properly. In other words, after the Auto Level has finished, check to make sure the RV is level.
It’s important you don’t move around in the RV during the Auto Level sequence as it throws off the sensors.
Here is a good video on the Equalizer System and how to reset the Null Point.
https://youtu.be/oyDDO-RudJA
